| | | Forums66 Topics128,258 Posts1,058,083 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 26 'Bolter | | 'Bolter Joined: May 2016 Posts: 26 | I have a 49 Chevy Panel with 6 bolt, 6:00 x 16 tires and rims. Super old tires that still hold air. About to be roadworthy. Need to replace with something safe and hopefully cost effective. Would also like something taller at least in the rear (stock 4:11). Any input would be appreciated. Thank you PS I did try a search of the site but was unsuccessful.
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | LT215/85R16 is what I have on my panel. Original rims. | | | | | Joined: Oct 2021 Posts: 7,010 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,010 | Leo called it. That is the modern radial size closest to the original bias ply size. They're 30+ or so inches in diameter so you'll be able to travel down the highway faster at lower engine rpm.
The good thing is there are plenty of different brands to choose from on Amazon for about $100 each.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2022 Posts: 2,514 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,514 | Same LT215/85R16 on my 3/4 ton 52 GMC.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: May 2016 Posts: 26 'Bolter | | 'Bolter Joined: May 2016 Posts: 26 | Thanks gentlemen. Great info! Do i need to seal the rims? | | | | | Joined: Oct 2021 Posts: 7,010 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,010 | Not if they're in good shape with no rust inside. Make sure the beads are smooth and true.
A friend of mine had some '58 Cadillac Sabre wheels that are riveted together. They wood gradually leak air through some of the riveted areas.
He painted the inside of all the wheels with Flex Seal and hasn't had any leak downs , since.
| | | | | Joined: May 2016 Posts: 26 'Bolter | | 'Bolter Joined: May 2016 Posts: 26 | | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Here's a highly rated reasonably priced option I see on Amazon Starfire Solarus HT All-Season LT215/85R16 115R Tire
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
