4 members (Shade Baby, Otto Skorzeny, Pinetree, Deegs53), 143 guests, and 2 robots.
Topics128,258
Posts1,058,083
Members48,482
2 Offline
I have a 49 Chevy Panel with 6 bolt, 6:00 x 16 tires and rims. Super old tires that still hold air. About to be roadworthy. Need to replace with something safe and hopefully cost effective. Would also like something taller at least in the rear (stock 4:11). Any input would be appreciated. Thank you
PS I did try a search of the site but was unsuccessful.
Leo Offline
Moderator
Moderator
LT215/85R16 is what I have on my panel. Original rims.
O Online: Content
Leo called it. That is the modern radial size closest to the original bias ply size. They're 30+ or so inches in diameter so you'll be able to travel down the highway faster at lower engine rpm.
The good thing is there are plenty of different brands to choose from on Amazon for about $100 each.
1950 Chevrolet 3100 (Ol' Roy)
Same LT215/85R16 on my 3/4 ton 52 GMC.
2 Offline
Thanks gentlemen. Great info!
Do i need to seal the rims?
O Online: Content
Not if they're in good shape with no rust inside. Make sure the beads are smooth and true.
A friend of mine had some '58 Cadillac Sabre wheels that are riveted together. They wood gradually leak air through some of the riveted areas.
He painted the inside of all the wheels with Flex Seal and hasn't had any leak downs , since.
2 Offline
Thank you
Here's a highly rated reasonably priced option I see on Amazon
Starfire Solarus HT All-Season LT215/85R16 115R Tire
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
