8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16089 11/06/2003 10:32 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 |
#16090 11/06/2003 3:05 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Luke, Mapquest tells me that Windsor to Cleveland is only 170 miles. It's an honest mistake.
How are GM guys supposed to know what you are talking about? By the way, that Cleveland was a great motor. I can not say how I know this but trust me, they are good motors. | | |
#16091 11/06/2003 8:40 PM | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | I guess we,ll give credit where credit is due. In 1979 the cleveland engine went undefeated in Pro Stock N.H.R.A. drag racing by who? B-- -------.  | | |
#16092 11/06/2003 9:19 PM | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | | | |
#16093 11/07/2003 12:21 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A police officer owned it and drove it but it doesn't have a title? Sounds legit to me. | | |
#16094 11/07/2003 4:26 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Old 55, that would be Bob Glidden or something like that.The early Clevelands were good runners, the later smogged version and especially the M models were gutless block crackers.I believe the Cleveland was discontinued around 1980 and the Windsor was the engine of choice. | | |
#16095 11/07/2003 4:30 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Bob Glidden is back in action this weekend at the NHRA Finals in Pomona, CA (Driving a MOPAR!) | | |
#16096 11/07/2003 6:35 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I thought the cleveland was introduced about '71 and went out in '75. Good motor, but didn't really have a place in **** 's engine lineup at the time. I think the 351C was based on the 302, and the 351W was based on the larger engines. Different firing order, water jackets, 351C and 351W/M are supposed to be a lot different.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#16097 11/07/2003 7:39 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | 351C is a low deck, canted valve design. The heads appear similar to the 429/460 or a BBC. It is no kin to the 260/289/302/351W family of inline valve engines. 351C has 8-bolt valve covers, 351W has 6-bolt valve covers. The 351M/400 tall deck is a variant in the Cleveland family, but doesn't lend itself to hot-rodding like the 351C. The 70&71 4 Barrel (351C-4V) was available with quench heads and the monster ports (You could fit a pack of cigs down the intake ports), but in 72 they were replaced by open-chamber heads, still with the large ports. 2 barrel heads had much smaller ports and open chambers, as did the 351M/400. The 351C survived until 1974; in 1975 it was replaced with the 351M/400. The Boss 351 , a specialized 351C-4V with screw-in studs, hotter cam, etc., was really the most streetable of the 3 Bosses (302, 351, and 429). It had a generous torque curve and plenty of breathing for the top-end. More about ***** than some of you wanted to know, but it the 351C-4V is a good engine and worthy of respect. | | |
#16098 11/07/2003 11:24 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Frud has "IN STOCK" a half set of main bearings (the lower half  :rolleyes: ) for the 400M (Morphedite). Apparently the upper half does not wear like the lower half does. -
#16099 11/10/2003 6:01 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Seeing that upper radiator hose with the thermostat laying sideways in the intake manifold reminded me of a bad experience I had this past week.
My service truck at work is a 96 F**d with a 5.8L (351 Windsor). I noticed that the thermostat was not closing and I just about froze when the weather turned cold. I procured a new thermostat and gasket and proceeded to install them. Being lazy, I did not remove the upper radiator hose as it had one of those spring-type clamps that I didn't feel like messing with. BAD IDEA!!!!
In the process on installing the new thermostat, it slipped down out of the groove and when I tightened the housing bolts, I heard the sickening snap of aluminum cracking. Our local F**d dealer wanted $98.00 (yes $98.00) for a new housing. Luckily a buddy of mine who runs F**ds let me have for $5.00. The next time I was VERY careful when installing the thermostat.
Whoever thought the thermostat should lay on its side should have had his head examined. Maybe this was some bean counter's sick idea of how to make extra bucks. | | |
#16100 11/10/2003 2:28 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Carl - You are a long way from the first guy to crack a thermostat housing because it was misaligned. Cast iron or cast aluminum, they are all vulnerable when the thermostat is off the lip or they are cockeyed. | | |
#16101 11/10/2003 8:18 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A lot of engines have sideways thermostats. Even the Perkins turbo diesel in my dad's boat has one.
