1 members (Gray_Ghost),
83
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 2,449 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,449 | We now have a rider-only 4 wheeler, a 48" Gravely zero turn mower and a Polaris Ranger side by side. All of these use 87 octane gas.
Question: How long should I keep a 5 gallon plastic gas can full before dumping it into one of the Toyotas or my 52 GMC and reloading the can on my next trip to town? The can is kept in a garage that does not freeze nor go over 90F.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | If your gas sits around for long periods of time, add Stabil to it when you first buy it. That goes for E-10 and non-ethanol fuel.
I've had E-10 for lawn mowers and whatnot last over a year in gas cans without separating or gunking stuff up , but I wouldn't put it in a vehicle. Mixing "bad gas" with lots of fresh gas doesn't suddenly make the bad stuff good.
If you're buying non-ethanol fuel, a year or so old is ok if it's in a sealed can.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 5,844 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,844 | I always add Stabil to my portable gas tanks for small equipment/lawncare stuff and it's usually good for about a year, but I also usually consume what's in the tanks well before a year comes around.
Untreated, I wouldn't keep it longer than a couple of months before adding to your vehicles and filling with fresh gas.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | I've encountered 3 month old "gasoline" that hadn't been treated with stabilizer that could just barely be lit with a match- - - -definitely not a spark plug! One of my former students and I struggled for 3 hours to start an engine, and failed miserably until we used fresh gas! Jerry
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I also add Sta-Bil to all my gas containers whenever I fill them up. And since my trucks don't get driven that much either, I add the proper amount to them also whenever I put gas in them. | | | | | Joined: Jan 2022 Posts: 2,449 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,449 | I could put a reminder on my phone's calendar once a month to drain the gas can into the 2 everyday drivers we have and refill the gas can. Cheaper than putting 5 gallons worth of StaBil in and keeping it for longer.
| | | | | Joined: Nov 2004 Posts: 2,407 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,407 | Toward the end of the mowing season I always add Stabil to the gas in the cans. That way what ever gas is left in the mowers has been treated. I also do not run any ethanol in my outdoor equipment.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2021 Posts: 214 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 214 | I’ve been using non-ethanol 91+ in my vehicles for as long as it has been available. One vehicle already requires 91+, which is designed for no ethanol. It does cost a bit more than standard high octane, but what I do have in containers will run the yard tools and generator just fine. Had some cans probably 2-3 years. It also gives me personally 1-3 more mpg on the trips. That is huge on 400 mile trips, which I take 2-3 times a year. It also completely eliminated the pre-ignition ping even compared to standard 91+ octane.
It does make it a challenge to find non-e stations though.
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | I'm a believer in Sta-Bil, I stored a lawn tractor for unplanned 5 years, Sta-Bil was added to the tractor gas tank and circulated through the fuel system upon storage, machine was re-commissioned, started and continues to run to this day. Winter storage of our jet-ski's, mower, etc always includes Sta-Bil prior to shut down.
| | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | Hottod Lincoln - When you say “gasoline” , are you referring to that which is enhanced with corn?
| | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | I’m on the Stabol added to non ethanol gas team. I put it in everything but my daily driver.
Just my two cents, but I wanted to share some personal observations about ethanol-blended fuel and its impact on small engines over the years. I can’t back this up with scientific proof, but from my own experience, ethanol has caused me more headaches than I’d like to count.
Years ago, when ethanol was introduced into the fuel industry, I began encountering regular carburetor failures. Having a primary home in the Northeast and a secondary home in South Carolina, my yard equipment would sit unused for months at a time. During these periods, ethanol’s tendency to absorb moisture and gum up carburetors became a real pain. At its peak, I was cleaning out three or four carbs annually—often just as I needed them most! It reminded me of the present day battery failure rate with my yard tractors, wheelers, and even my jet ski, always at the worst possible times.
Back in New York before moving to my retirement home in 2013, non-ethanol fuel wasn’t available, so I was forced to deal with these issues. Now that I can access non-ethanol gas, those issues have nearly vanished. The difference has been night and day.
To cover all bases, I also mix Stabil into every tank of gas (except my daily driver) whenever I fuel up. It’s a simple step that eliminates the guesswork of tracking which equipment got treated. I use this routine across everything: my ’52 Chevy Truck, my wife’s 2007 VW Eos (which also sits for months), all the gas powered yard equipment and all of my toys.
To me, it gives me a bit more time to work on the projects I want to work on, making room for what inspires me, not just what demands my attention.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2022 Posts: 2,449 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,449 | Okay guys, you've convinced me. I'll dump the 5 gallons of ethanol-laced 87 octane I bought last weekend into one of the Toyotas and buy a couple of gallons of non-ethanol gas in Kerrville (nearest at 20 miles away) the next time I'm over there. And get some Sta-Bil.
Problem is these off-road vehicles don't get used much. Should I drain most of the gas from them now and replace it to the quarter or half level with some Alcoholics Anonymous approved gas/Sta-Bil mix?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You won't be sorry you spent a little more for gas in the end...I've had Non-Ethanol with Sta-Bil in storage for years and it's been fine! When I got my Fire truck it had been parked with non-ethanol for 7 years and it started right up! | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Hottod Lincoln - When you say “gasoline” , are you referring to that which is enhanced with corn? It's definitely a factor- - - - -like our resident fuel system guru "Carb King" refers to it- - - - -"Deathanol"!
| | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | Perhaps you have hit upon a business plan. | | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | As an aside , it wasn’t long ago that corn was said to be terrible for the environment- high nitrogen requirement, soil depleting , etc. Now corn is an environmental protection?
As my daddy told me on my wedding night - You can’t tell the players without a scorecard. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Moparguy,
I live in Atlanta where ethanol E-10 was mandated for clean air in 2007. Unfortunately the fuel companies aren't going to brew up E-10 for the 15 county metro area only and then supply the rest of the state with unadulterated fuel. It's all you can get anywhere with the exception of the random E-free 90 or 91 for $1/gal more.
Anyway, despite all the initial fear and hysteria about old car fuel systems being ruined by ethanol, I have not experienced it in nearly 20 years of using E-10.
I don't like it (It results in lower fuel economy), but it hasn't been the total disaster that many or most feared.
Two months after its introduction, the original fuel pump in my '56 Cadillac failed. Ethanol had stretched the diaphragm and wouldn't pump the requisite amount of fuel. When I replaced it with an ethanol tolerant pump, everything has worked as it should.
Ol' Roy has used E-10 87 exclusively since being brought back to life 5 years ago. I rebuilt the Carter YF carburetor with Jon H's regular kit with the standard black rubber accelerator pump and have had absolutely no ethanol related problems.
Even my chainsaw and yard equipment uses the E-10 without trouble of gunking up. I do use Stabil for long term storage in the can.
I wonder if the same formula for E-10 is used everywhere or if Atlanta has some different blend that is less damaging to rubber parts? I do use all my cars regularly so the stuff doesn't have a chance to sit around and cause trouble.
It seems like the only E-10 related problem I seem to be experiencing lately (never before on any vehicle over the last 20 years since it's introduction) is vapor lock. Several of my cars (not Ol' Roy) have recently fallen victim to the much lower temperature at which modern fuel begins to vaporize.
The installation of helper electric fuel pumps just ahead of the mechanical pumps seems to have solved that issue. When the stuttering or hot start issues begin, turning on the electric pump solves the issue immediately. Once moving down the road, the electric pump is switched off and the mechanical pump is used exclusively.
| | | | | Joined: Jan 2022 Posts: 2,449 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,449 | As my daddy told me on my wedding night - You can’t tell the players without a scorecard. You were hanging around with your daddy on your wedding night?
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | As my daddy told me on my wedding night - You can’t tell the players without a scorecard. You were hanging around with your daddy on your wedding night? Hahaha! Good one, Bill.
| | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | That was my first wedding. As it turned on I would have been better off skipping it completely. | | | | | Joined: Sep 2009 Posts: 5,844 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,844 | We are getting WAY off into the weeds here fella's - hahaha!  Let's get back to the "gas" conversation please and thanks.
| | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | Yeah , but we’re enjoying ourselves. | | | | | Joined: Nov 1995 Posts: 5,718 62401 | | 62401 Joined: Nov 1995 Posts: 5,718 | Back on point ... just to add my voice to this argument -- I've had first hand experience (as has Mike Roache, Mike B and anyone else who was in that awful convoy to Winchester years ago) as to just how destructive that Ethanol crap is -- Nothing like watching (from the driver's seat ...) a freshly painted firetruck catch fire in the engine compartment because the fuel system disintegrated on a road trip. Only Mike Roache's quick, professional reaction saved that truck. My two modern drivers ('14 E-350 and the '19 VW) are the only things I put that crap in. Everything else (that burns gasoline  ) gets real gas. I prefer the 89 octane non-ethanol for the little 2-stroke engines (chainsaws, weedeater, etc) but I haven't discovered yet where that can be obtained in NE Alabama. I recently fired up my little saw (Stihl 250). It hadn't run in more than two years and the gas in it was probably a year old then. Started on 4th pull and ran fine. My other two Stihls (a 440 Magnum and the MS360) are both more than 20 years old now, I've owned them since new and have run nothing but non-ethanol fuel (89 Octane until we moved here) and the Stihl-branded 2-cycle oil. They both run like they are still brand new.If I was not going to use the gas for 5 years, I might add stabil to it. But I don't store fuel that long. My generator (actually, a Hobart portable welder) is 26 years old. Stays with a full tank of non-ethanol in it at all times (with the fuel valve closed). Kohler engine. To run it, I just open the fuel valve, count to twenty and it'll start first pull. Same with the Robin (Subaru)-engined pressure washer and log splitter. Those who have problems with little engines starting on real gas either have maintenance issues or you have a crappy engine (Briggs or Tecumseh). Go German (Kohler) or Japanese (Kawasaki, Subaru, Honda, Yamaha, etc), and only run REAL gas, if you want good, long reliable life out of a little engine. On bigger engines like our automotive engines, unless the vehicle was designed and built to handle ethanol contaminated fuel ... you are not doing your engine any favors by running that crap. Bottom line -- if you hate your engine and want it to die, run the ethanol fuel in it. I think it is pure crap and the environazi's are using it to destroy all internal combustion engines. Around here, I have to go off the mountain to get real gas. And its more expensive. I'm told I have to go to Huntsville to find 89 Octane, but I haven't checked the marinas around here yet. But maybe the more we consumers reject that crap and demand better fuel, it may become more readily available (even out here on the distant end of the supply chain ...) I wonder if I could mix 87 octane with 100 octane low lead from the airport? Either that or I may just start buying the pre-mixed Stihl fuel at the Co-op. Yes, you pay more for anything that's Stihl branded but my stihl equipment speaks for itself (3 chainsaws, pole saw, weed eater, brushcutter, blower) -- all *look* 20 years old, but they all run like new and start easily. Its more cost effective to pay more for the gas, oil and parts than to replace this stuff after 10 years. I bet when they have an estate auction to get rid of all my stuff in 20 years, it will all still be running great... if I don't neglect it ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | I don't know about Alabama, but the Co-Op stores in Tennessee sell non-alcohol gasoline. The closest one to you will probably be in Fayetteville. The low lead 100 Avgas burns a little slower than 87 octane, so the only downside to using it might be a bit hotter exhaust temperatures even if you don't mix it with 87. On the race engines I used to build, I ran avgas with 5% Diesel fuel by volume mixed in, to get the equivalent of about 105 octane- - - - -at just over half the price the racetrack wanted for the Pure Firebird racing gas they tried to make us run! Jerry
| | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | John, here is the link for where to buy real gas. Check your state. Pure-gas.org
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 1995 Posts: 5,718 62401 | | 62401 Joined: Nov 1995 Posts: 5,718 | Thanks Wayne!! Found one I'll try.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2022 Posts: 2,449 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,449 | Thanks from me too Wayne. I pass one I didn't know about on the Pure-gas list every time I go to the gym in Fredericksburg, probably 5-6 times a week. Saves me a 45 mile round trip to Kerrville.
| | | | | Joined: Aug 2001 Posts: 3,596 Moderator | | Moderator Joined: Aug 2001 Posts: 3,596 | I have doing about the same thing John described for many years and have never had any problems with non-ethanol fuel used in any of my engines that may sit for 6 months+ or for a couple years. I guess I am lucky in that there is a Caseys station in town, only about 12 miles away, that has its own non-ethanol nozzle. Yes, it is about a buck higher per gallon, but it is well worth it to not have any issues. Another site I use mainly when I travel is GasBuddy. It shows Realtime fuel prices in the US. https://www.gasbuddy.com/gaspricemap?lat=38.822395&lng=-96.591588&z=4Don
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | This thread reminds me to pull out the generator and give it a run. We had a mild Winter last year and I didn't have to use it. So, that gas is old!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | I use GasBuddy also but I don't think it tells you if the gas is ethanol or ethanol free | | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | I probably should not give voice to the following , but , given the massive scale of the ethanol industry and the government involvement in subsidies , lobbying ,etc. I am amazed that uncontaminated gas is still available. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | They have to keep making it for airplane use anyway since ethanol is not allowed in aircraft engines.
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | As long as they keep making Budweiser, pickled eggs, cabbage rolls, and Taco Bell- - - - -I don't think we'll ever have to worry about a gas shortage! LOL! Jerry
| | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | I always run my generator dry at the end of each hurricane season. I've had it 20 years now and it's never failed to start. I use nonethanol only in it. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | They have to keep making it for airplane use anyway since ethanol is not allowed in aircraft engines. Av gas is wonderful stuff. Minimal additives , plenty of lead. An important part of a preflight procedure is to draw fuel samples from each tank and examine it to verify the correctness of the fuel and freedom from contamination. (Av gas is easy to visually identify because of it’s pretty blue color.) It is common to get gas on the hands when performing that function. I never worried about stinking up the cockpit because all I needed to do was wave my hands around in the open air and the fuel would evaporate with residual odor. If I get automotive gasoline on my hands it takes multiple washings to get the stink off. What IS all that stuff that stinks so badly ? Av gas is relatively unadulterated because airplanes cannot pull over and park if the engine stops functioning. Aviation demands GOOD fuel. | | |
