2 members (latroca52, crenwelge), 149 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,469
Page 7 of 7 1 2 3 4 5 6 7
NJC
Offline
26 JULY 2026 PASSENGER JUMPSEAT BACK UPHOLSTERY DONE
I bought all the supplies to begin the upholstery from Jim Carter's ($1200) to include seat kits, upholstery, paint for the frames, and hardware. See pics of the initial back of the passenger seat (original and the first one I've gotten done thus far.
Donald S.
Donald S.
NJC, looking good, I spent this afternoon catching up on your project. I am just at the beginning stages on my Suburban 3116 with the clamshell doors. I am taking a different route compared to my 53 truck. Getting pretty close to being done on the major sheetmetal work. Keep up the good work on yours!!πŸ“ΈπŸ“Έ
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
NJC
Offline
31 JULY 2026 PASSENGER FRONT JUMPSEAT BOTTOM UPHOLSTERY DONE
I completed the passenger front jumpseat bottom. I will now move on to the larger driver's seat. I do have the frames for the passenger and driver seats already primered and need to final paint them on a day with low humidity. Meanwhile will continue the upholstery work. See pics.
Thanks for commenting Donald.
The passenger seat bottom looks great, probably better than new!
1949/50 3600 Project
Follow in Project Journals
AD Addict & Tinkerer
You upholstery job looks great!
Phil
Updated to: β€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
Nice work as always Nick! thumbs_up
~ Dan
1951 Chevy 3 window 3100
NJC
Offline
2 AUGUST 2026 DRIVER'S SEAT BOTTOM COIL SPRING REPLACED, CLEANED UP, PAINTED AND JUST ABOUT READY FOR UPHOLSTERY
I had to replace 1 broken coil seat spring directly under where the driver sits. I used 1 from the old passenger seat. I spent a couple hours using the wire brush dremel & 1/2 inch mini sander to remove rust & grime before applying initial coat of black paint.
See pics of how the seat came, and the spring bottom afterward.
Thanks for the comments Wicruiser, Phil, and Dan
NJC
Offline
7 AUGUST 2026 DRIVER'S BOTTOM SEAT UPHOLSTERY DONE
I finished the upholstery on the driver's bottom seat today. I had bought 2 seat kits from Carter's that has the burlap, the heavier fabric, the cotton, and the c clips. So 1 kit did 3 cushions and I still have 5 cushions to go. The 2nd kit won't finish it all. Plan on 3 kits if you are doing all the suburban seats as originally sold.
See pics.
Looks great!
Great job!
Phil
Project Journals
NJC
Offline
8 AUGUST 2026 DRIVER'S SEAT BACK SPRING CLEAN-UP, PAINTED, AND HISTORICAL INFORMATION ABOUT WEYMOUTH INSIGNIA
I cleaned up another seat spring using dremel wire brush, 1/2 inch by 18 inch belt sander, tedious hand sanding and then painted it black.
Some history on the original vinyl manufacturer. The stamp on the backside of the Suburban's seat material refers to Weymouth Art Leather Company (East Weymouth, MA) founded in 1911 and ceased operations in 1989. GM contracted Weymouth to supply the massive rolls of heavy-duty commercial grade vinyl where it was stretched over the seat springs. My suburban was built at Tarrytown, NY.
Thanks for comments Wicruiser and Phil.
See pics.
Nick - As always, such meticulous work! Always impressed. [notworthy]
The information abut the "Weymouth" material supplier is a great tidbit of info. Thanks for sharing. thumbs_up
~ Dan
NJC
Offline
9 AUGUST 2026 DRIVER'S SEAT BACK CUSHION UPHOLSTERY COMPLETE, UPHOLSTERY TIPS, FRONT SEAT FRAMES PAINTED
I have completed the upholstery on all the front seats now and have begun painting the frames using Carter's dark red brown acrylic for suburban seats and interior trim.
2 tips I use when doing upholstery: 1) set the upholstery out in the sun to warm up; and 2) use pieces of masking tape on the upholstery underneath the c clips and when using plyers to tighten the c clips in place.
Thanks for comments Dan.
See pics.
NJC
Offline
15 AUGUST 2026 DRIVER'S SEAT INSTALLED
Today I installed the driver's seat frame and then the bottom cushion followed by the back cushion.
Previously I had built a top out of OSB board for the tool compartment under the seat and had to trim it on the end widths to fit. Someday I may find an original cover as this project didn't come with one.
See pics.
Nice job. Those were pre-sewn seat covers, right? They fit pretty well.
1950 Chevrolet 3100 (Ol' Roy)
NJC
Offline
16 AUGUST 2026 PASSENGER JUMP SEAT INSTALLED
Installed the passenger jump seat frame followed by the the re-upholstered cushioned springs. See pics.
Yes Otto the upholstery is sewn together already and is available from Jim Carters (Independence, MO). Thanks for the comments.
Looks great, nice job! chug
Phil
Project Journals
NJC
Offline
5 SEPTEMBER 2026 CLEAN-UP MIDDLE SEAT FRAME
I have been removing dirt, rust, and original paint from the middle seat frame. It's a chore for sure using electric hand tools. This frame and the rear frames and springs were bought years ago from a stovebolter out of MI and I had used greyhound bus to ship them to its terminal in Baltimore. They must of sat in a barn for years. IDK.
See pics.
Thanks Phil for the comment.
NJC
Offline
7 SEPTEMBER 2026 PAINTED MIDDLE SEAT FRAME AND STARTED MIDDLE SEAT BOTTOM SEAT SPRINGS REFURBISHMENT
I checked my receipts from 2012 and I had bought the middle and last full width seat frames and the seat spring sets with delivery from MI to Greyhound Baltimore for $2217.00. A lot of suburban's are missing those original seats.
See pics of work completed thus far.
NJC
Offline
20 SEPTEMBER 2026 BEGAN SLIDING SIDE WINDOWS INSTALL
I bought the 8 pieces of glass from Auto City Glass (MN) for $479 and suburban side window weatherstripping kits from Classic Parts (MO) for $225.
The glass thus far is about 1/4 inch smaller than the original and I am making it work.
I've done the first window but still need to seal it good with clear weatherstrip adhesive permatex.
A tedious job is removing old catwiskers from the stainless and you will use that stainless strip on the new larger window of the 2.
See pics.
I believe Suburbans have a trim piece for the stationary glass. Most seem to be missing them. Previously, we found a possible replacement.
Suburban Side Window Stationary Window Trim
NJC
Offline
27 SEPTEMBER 2026 PASSENGER REAR SLIDING AND STATIONARY WINDOW INSTALL
Got the 2nd window set installed & had some help with a buddy of mine that happened to stop by. See pics.
Thanks Mark on a source for stainless holding catwiskers source
Donald S.
Donald S.
Is there a detail dwg. somewhere that shows the various parts and or details for these windows? I am not at that point yet but want to look at it now to plan. Another question, are there any sources for the exterior trim on these windows, I have looked at what I have and it’s pretty rough.
1953 Chevy 5-window
back yard wrench turner
Don, have you looked at Keith Hardy's online manuals. It has a wealth of information on our old Chevy and GMC trucks.
Keith Hardy manuals
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Don - Take a look at this "Legacy Tech Tip" 1951 Chevy Suburban Side Window/Quarter Window Step-by-Step Installation. I think this will give you something towards installation guidance help.
There are two illustration pages in the 1929-54 Chevy Master Parts Book that Wayne is referring to*, Side view of a Suburban w/end gate and Rear View of a Suburban/Carryall. Unfortunately they don't do a good job of showing all the pieces needed and I can find no diagrams in the 1947-54 FAM.
There may be more info in previous posts on the subject, but we'd need to do some searching to find them.
* NOTE: While attempting to access the Keith Hardy Old Car Manual Project Site through the main page link, I got an error code that won't allow access to the page and all the direct links to each of the manuals/documents they have. It appears they are instituting "Cloudflare" and are suffering from some growing pains, which is prevent access to the main page. There is a partial work around to get access to at least some of the content for anyone that has a direct link to any specific page in one of the manuals they have uploaded. I used a link to a specific page in the Master Parts Book noted, which allowed me to click other links on that page to get to all the other content in that one book. The same should be possible if you have a direct link to pages in the other manuals. Edit Update - After contacting the webmaster at Keith Hardy's Old Car Manual Project last night and reporting the problem accessing the main page, he's managed to fix it and access has been restored. They too just instituted "Cloudlflare" due to overwhelming "bot" attacks and like us are getting things right to block the "bots" and maintain access. thumbs_up
~ Dan
Donald S.
Donald S.
Thanks guys, I will dig into this too. I also need to evaluate the outside trim closer to make sure it is repairable.
1953 Chevy 5-window
NJC
Offline
12 OCTOBER 2026. COMPLETED SIDE WINDOWS
I completed the side windows & now just have to make the stainless locking mechanisms out of some kitchen tongs found at the thrift store. Why? Carters use to sell them but they don't know whether they will ever get them in again.
See pics.
There are no directions to install these except what was written up on this forum.
That's pretty funny. Those tongs were made for the job.
I didn't know that sliding windows were available on those AD subs. Not that I have any knowledge about them to begin with.
How do those locking mechanisms work?
The latch is a piece of spring steel. You slide the window past and it falls to a position behind the trim.
Moderated by  Phak1
