5 members (Cletus1950, Otto Skorzeny, dt235sd, Brian Moore, jeffreyguy), 151 guests, and 5 robots.
Topics128,107
Posts1,056,225
Members48,436
Anyone know the part number for these ?
What year? I'm not sure the short (pre 54) and tall (54 and newer) distributors use the same point set.
Most over the counter condensers are crap. Buy your condenser from Jon G on this forum.
The engine is a 1952
Had some time with my parts books. Appears that the point set is the same on short or tall distributors. Delco Gold D111 or United CP801 should work.
Unless the 302 is a military engine. That distributor is 24 volt and waterproof. Looks much different than regular distributor.
