Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 61 guests, and 5 robots.
Topics128,003
Posts1,055,244
Members48,418
Page 2 of 2 1 2
Neither will lock from the inside.
On my '52 (with push button outside opening on one side only) I bought a new push button lock and put it into the handle that needed a lock on the outside. Had a locksmith redo the pins in the new lock mechanism to match the original lock on the other side push button.
I don't remember the details on turn down handles with separate locks (pre-52), but I have a friend that has a '50 GMC with Altman latches. I know he can lock either door from the outside. I can call him for details tomorrow if you'd like me to.
Donald S.
Donald S.
Yep, that’s what I figured. I did the same on my 53 and had the key lock for both sides.
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
Donald S.
Donald S.
UT OH!! And I thought I was done with major sheet metal work. They must have had a leak at the top of the windshield that ran down that corner and rotted all the way to the radius. The good news I can buy that part.
Drivers side corner
Passenger side corner
1953 Chevy 5-window
U
U Offline
That's why I was thinking about getting a new rubber windshield gasket. The old one is hard as rock and probably brittle.
~ John in Utah
Here We Go
Follow in his DITY Bay
Donald S.
Donald S.
Got my 4.3 back from the engine builder and since I am a sheet metal guy but not an engine builder I decided to have that done. Can’t wait to get it back on the frame to at least hear it run.
4.3 V-6
1953 Chevy 5-window
Donald S.
Donald S.
Been dividing my time between the rusted windshield area and reassembling the front of the engine so I can get the serpentine belts back on to crank it up. Next is the water pump as soon as I get the gaskets. I am not putting headers but stock exhaust manifolds that I have to clean up and paint with high temp paint. As far as the rusted a pillar and the area across the bottom I have most of that repaired. The inside corner radius was fun, but I made a nice corner template of heavy card stock to assure the fit. Last part to do is actually the upper corner of the dash. I will get a picture of it next week. I do have a couple pinholes at other locations along the windshield area that I need to check out and fix. These are not nearly as bad.
4.3 engine
4.3 engine
A pillar rust repaired
Bottom of windshield area
1953 Chevy 5-window
Donald S.
Donald S.
I know I said early on that the wife would be involved and she has. She has decided on a paint color that we saw while at SMN in Townsend. The burb may end up two tone with some pearl white from the bottom of the windows up. We’ll see. I may look for an app that can add these colors to easily visualize it.
Paint color
1953 Chevy 5-window
Donald S.
Donald S.
So I got the bottom radius corner of the windshield frame rebuilt on the drivers side and doing the PS, it wasn’t as bad.
Windshield Frame DS
PS tacked together
1953 Chevy 5-window
Good work! If the driver's side was worse than the passenger's, then it was pretty bad. But you've done a great job in fixing both. Fortunately my windshield area wasn't bad at all. I went back and looked at your previous pics and that was pretty ugly.
Donald S.
Donald S.
So…. Today I found a new spot that also needed repair. My original plan was to weld up the unused holes across the bottom of the dashboard. Half of the bottom front edge under the glove box had bondo and primer. I cut it out and partially welded the new metal back in.
Bottom of glove box repair
1953 Chevy 5-window
U
U Offline
I really appreciate those that have metal skills. Although no one might see that, the repair looks great. Just wondering how that rust happened? Was it water running down from the corner of the windshield?
~ John in Utah
Here We Go
Crusty Old Sarge
Crusty Old Sarge
It's to bad your not closer, I would trade an engine build for some metal work...
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Donald S.
Donald S.
I would have taken that deal. Just got the 4.3 back for the cost of a V-8. 🤣. Honestly the price wasn’t bad, I had him supply a bunch of extras, carb, little cam, distributor and intake. Oh well I don’t feel like I can do it all.
4.3 V-6
1953 Chevy 5-window
Donald S.
Donald S.
A couple of days work here, got the bottom of the glove compartment done all ground flush and fixed. Plugged seems like 30 more holes under the dash and a few other pinholes and over ground thru spots. I pulled the front fenders out that the PO did some work on and found the flanges on both where they hit the cab rusted out. Cut those out and tack welded a new flange in place. Weld and grind them tomorrow. I wire brushed everywhere I could get inside the cab so I’m pretty much done with the inside. I decided to go ahead and spray a couple of coats of Eastwood encapsulator on the floor, up the kick panel, firewall and under the dash. Before carpet on the floor, my interior plan is to install the 3 boxes (from the PO ) of Killmat soundproofing everywhere I can. I used a similar product on my 53 and am happy with the sound deadening properties, especially opening and closing the doors.
Glove box frame done
Front render flanges
Flanges tacked in
Inside cab painted
1953 Chevy 5-window
Crusty Old Sarge
Crusty Old Sarge
I have been showing a friend your progress, he has zero motivation (not self winding). He was impressed, and should be.
I built him a nasty 292 some years back and it's still setting on the engine stand. He really liked the idea of a 4.3L.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Donald S.
Donald S.
Yep, I got a buddy here with a 1966 Goat that I can’t get to either move it forward or get rid of it. He is like more than half way done but put it down yrs ago. He needs the room in his shop.
1953 Chevy 5-window
Page 2 of 2 1 2
Moderated by  Phak1
