| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2025 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2025 Posts: 62 | As I move toward an open drive line in my 54 with manual trans, I find many transmissions for sale that can be accurately evaluated only by the cast or stamped numbers. I have found the necessary decoder for engine numbers, but similar for transmissions are skewed toward automatics, and a search of this forum wasn't sufficient, and AI isn't as smart as it claims. The unit I am currently looking at has cast numbers GM4, GM H246, and 8889564. I believe it is a 1960s 4 speed, but have no more info than these numbers. Is there a comprehensive list of casting numbers for the several makes of GM transmissions? | | | | | Joined: Sep 2009 Posts: 5,823 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,823 | Can you provide pictures??? Many casting numbers can be found in the Chevy Master Parts Books, using GM Partswiki searchable database. I just did a quick check using that casting number and came up with no matches unfortunately.  Casting numbers are notoriously known for being difficult to read/easy to misidentify, so picture are a big help getting past that issue. Also of importance is the transmission has many different casting numbers. Main case, tail shaft housing, side cover, etc. The most important one to start with will be the one on the main case. Please post some pictures,if you can and we offer more help.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2009 Posts: 5,823 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,823 | As a follow up to above, the transmission should have a "stamped" (not cast) Alpha-Numeric serial number on the main case, often on the tail shaft housing mounting flange or the side cover mounting flange (machined surface). That info can also be decoded to help identify the unit, coinciding with the main case casting date code.
"H246" in general decodes as August 24th 1956 (or 1966 or 1976), as the last digit only indicates the year but not decade built.
| | | | | Joined: Nov 2025 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2025 Posts: 62 | That particular unit is no longer available, but having a list of numbers would be handy as I forge ahead. Deve's list of engine casting numbers was spot on and easy to use for my engine. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Hollander goes by casting number rather than part number because salvage dealers went by casting numbers rather than by part number. However casting numbers are not indexed. The casting number you cite does not come up to a Chev or GMC 4 speed in my 1966 edition of my Hollander. A 48-54 SM 420 will hve a casting number of 591907. If it is in a half ton, it will be a torque tube. a 3/4 and 1 ton uses the same case with a half closed drive shaft. a 1 1/2 ton uses the same case but is open drive shaft. A SM 420 with a casting 3837332 would be a 55 and later with an open drive shaft. | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Try looking at Novak transmission site it has a description of the casting differences between the years of the sm 420 but not sure on the numbers .if you want a open drive using a sm 420 they were used from around 1948 to 1969 with small differences the older ones will work but you will need the rear bearing cover from a newer one with the yoke for the u joint and seal .The 68/69 ones have a reverse light switch on the top cover.There also may be newer models that were used in military vehicles. | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | SM465 came out in 1968, replacing the SM420 in most applications. SM420 continued in some military application afterwards.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | Shopping for a SM420, I would look for a 7 digit casting code which indicates a later model. You can still get syncro rings for the later models. If it has a backup switch, that's a bonus.
ps. the casting code 8889564 was probably 3889564.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
