4 members (TUTS 59, Maybellene, baldeagle, Hanks custodian), 61 guests, and 2 robots.
Topics128,060
Posts1,055,835
#1608390 07/25/2026 1:13 PM
Ok so I confess, that when the rear was rebuilt and after it was all reassembled and painted someone looked around and thought I wonder what these are for. Like a Big Dummy I forgot to install the oil slingers. The bearings and seals were by Timken I believe, need to look at the receipt. What are the chances this is going to cause a big problem down the road literally. This is one of the reasons I need a test drive, I really don't want oil soaked rear brakes! Has anyone ever done this and how did it work out. If I need to disassemble and install the slingers can the bearings and seals be saved? I don't believe Timken makes these anymore.
Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Shade Baby #1608448 07/26/2026 5:25 PM
Ok, I am removing the axels and installing the oil singers. The brakes need to be bleed anyway. Better safe than sorry.
Shade Baby
"Back In Time"
Follow in the DITY
Shade Baby #1608458 07/26/2026 8:33 PM
Good choice. Everything with a purpose and yes, better safe than sorry. wink
~ Dan
1951 Chevy 3 window 3100
Shade Baby #1608461 07/26/2026 8:53 PM
Since the bearings and seals are in the housing, not on the axle itself, removing and reinstalling the axles shouldn't damage anything. Just be careful not to drag the axle shaft over the seal lip.
