8 members (Bill Trotter, Hotrod Lincoln, JoergK., Cosmo, klhansen, Stovebolt48, 1955 1 Series, Bill Hanlon),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 3,457 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,457 | I have come across a complete '57 235. The Head is an 3836850 casting number. I'm not familiar with this head or combustion chamber. Has anyone had experience with one of these?
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2009 Posts: 6,045 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,045 | Craig - The "850" head is actually a 1956-62 "261" head according to my casting code info. The details about the '57 261's head can be found in the 1957 Chevrolet Truck Data PDF.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2007 Posts: 3,457 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,457 | Dan, I was aware of that as it crosses in my books. I'm just wondering if it is worth chasing as much as a "848". I looking for compression rating and measurements.
The seller claims it's on a '57 235.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2009 Posts: 6,045 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,045 | Craig - The only thing I could quickly find on the "850" 261 head was that it's introduction in '56 upped the 261's rated compression ratio to 7.8 to 1. Not sure how that affects it's use or compression ratio on a 235???
| | | | | Joined: Mar 2007 Posts: 3,457 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,457 | The combustion chamber is pretty similar to the "848", the valve size is the same. I may just take a chance on the entire engine, the price is cheap enough to make it worth the risk.
I'll let you know..
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2009 Posts: 6,045 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,045 | Cool  If I find something more on the head differences, I'll post what I find in case it may help in future plans for the engine.
| | | | | Joined: Sep 2011 Posts: 1,462 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,462 | 261 head (and gasket) has coolant passages drilled between cylinders 1 -2, 3-4 & 5-6.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | The 850 head will bolt onto any 235 from 1954-62 as well as the 261. It will have a very slightly lower compression ratio than an 848, but it's still a good head. It can be milled to raise the compression ratio to the same as an 848 as long as the intake valves are recessed the same distance as the head is milled. The six coolant spray holes between the cylinder pairs will have no ill effects on a 235 block- - - -they just won't flow any coolant because the 235 block isn't drilled for them.
| | | | | Joined: Mar 2007 Posts: 3,457 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,457 | I'm not concerned with the coolant passages, it's currently mounted on a 235. Externally the head looks the same as an "848", not sure about the oiling to the rockers, though I imagine it is the same.
A slight compression loss is not really an issue, the head will more than likely be resurfaced while being rebuilt.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | One of the 261 engines I have stashed away has its original 850 head. When I build up that one, I'll probably mill it to match the combustion chamber volume of the 848. A little bit of a compression bump and a Melling CCS-1 camshaft gives a noticeable gain in low end torque, without the problem of a lumpy idle and erratic manifold vacuum. Jerry
| | | | | Joined: Sep 2011 Posts: 1,462 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,462 | I'm running the CCS-1 cam in my 261, 848 head, coolant passage drill, 261 valve train, springs, exhaust valve rotator with stainless exhaust valves. Runs strong, smooth idle.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | A "261" with .060 over 265 Chevy V8 pistons, and a 4 1/4" stroke will have 291 cubic inches. That 850 head probably won't need to be milled if I build the engine like that. Those extra 30 cubic inches will give it plenty of compression. Jerry
| | | | | Joined: Mar 2007 Posts: 3,457 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,457 | I'm running the CCS-1 cam in my 261, 848 head, coolant passage drill, 261 valve train, springs, exhaust valve rotator with stainless exhaust valves. Runs strong, smooth idle. I have the same set up on an "848" head for a .060 over 235 I'm building. It uses NOS 1.940 intake valves from a '53 235, milled .040.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Manley makes a duplicate of that 1.940 intake, one that's designed to fit a custom cylinder head fora big block Chevy V8. The only difference in dimensions is the location of the keeper groove, which can be added by a quick, simple plunge cut with a parting tool on a lathe. The part number is 11583-1. Get ready for some sticker shock- - - - -they're E$$$$PENSIVE! Jerry
