1 members (1 invisible),
70
Mod | | | Forums66 Topics128,179 Posts1,057,160 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 6 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 6 | I am trying to find a rebuilt distributor or a full rebuild kit for my 1948 truck with no luck. My truck has the original 216 engine and the distributor has a mechanical advance. Any leads out there? Thanks… | | | | | Joined: Sep 2010 Posts: 2,333 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,333 | Try YouTube The jayhawker he has a video on rebuilding your distributer | | | | | Joined: Sep 2009 Posts: 6,015 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,015 | Haney - If you're looking for a replacement distributor or parts to do your own rebuild, post an ad in the Truck Parts Wanted Swap Meet forum. If your looking for help on how to do the rebuild, you can continue the conversation here.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2021 Posts: 6,951 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,951 | Contact Vintage Auto Garage. 800-516-4461
They will rebuild your existing unit for you and may also sell you the parts to do it yourself. The website isn't exactly clear but parts like dizzy bushings, etc are offered for sale. I'd call them for the straight dope.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Stovebolt distributor housings do not run bushings. The steel shaft runs in the cast iron housing, and there is a phenolic plastic thrust button and a spring under the grease cup that pushes the shaft sideways to compensate for housing wear. Once runout gets excessive, which creates variations in point gap and dwell, the distributor was supposed to be discarded and replaced. It's possible to ream the housing for bushings top and bottom to correct for wear, as long as the shaft isn't worn out of round also. A better fix is to bore the top of the housing for a Torrington needle bearing, and press a thin hardened steel collar over the shaft, ground to a minimum clearance fit to the bearing rollers. That's a job anyone who has the unmitigated gall to call himself a machinist can do pretty easily. Then the lobes on the cam can be checked with a dial indicator to assure they all have the same angular accuracy and lift. Then tweak the centrifugal advance to original specifications and be sure the vacuum chamber works properly. Jerry
