5 members (Charles in CA, Gdads51, TUTS 59, moparguy, Woodcmiami), 109 guests, and 9 robots.
Topics128,095
Posts1,056,078
Members48,433
#16080 01/18/2005 8:01 PM
Hello Wise ones,
I have a 12 bolt rear from 72 chevelle and want to convert the front to 5 lug drums on my 59 3100 apache panel. I heard that 53-54 chevy car drums and hubs are a bolt in deal. Does anyone have this stuff? and do I need the backing plates or will the truck ones work. Can I have the stock hubs and drums drilled to 5 lug?
Any other ways to do this besides going disc brakes.
Please help me if you can.
Thanks, Bill
yes, the earlier 5 stud car hubs will fit right on your spindles and require no other mods [besides 5 hole drums] the brake shoes and cyl's are identical - don't try drilling your drums - put an ad in the swap here, or look around the wreckers and swap meets - should be lots available down there w/ every one goin to newer subframes on the hot rod cars - I got a few sittin around here, but ain't lettin go of'em! grin
Thanks for the info, I found a pair of 54 car hubs and drums on the internet last night from Chevys of the 40s ph#1 800 999-2438 he said they have some good used ones for $150.(hubs,drums and backing plates)I have already converted the ball bearings to the later style via a golden state bearing kit, will this cause any problems?
Thanks again,
