2 members (Shaffer's1950, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 34 | 1/2 ton 3100 12 volt with starter motor, has two bolts to affix to bell-housing; top is the thread end coming out of the bell housing, lost the bottom bolt which is standard hex head bolt, what is the size of that bolt? | | | | | Joined: Jun 2018 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 95 | Should be a common 1/2-13 bolt found at any hardware store. If the lenght is important I can dig mine out. It;s currently soaking in degreaser.
1954 3600 Stakebed non-original engine out of a '55 passenger car with powerglide
| | | | | Joined: May 2015 Posts: 11,099 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,099 | Just happen to have mine handy, screwed back into the bell housing (engine currently disassembled.) It's 1-1/4" long and uses an internal star lockwasher.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2007 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 34 | | | |
