4 members (jay d, Youngin' Tut 59, TooMany2count, 1 invisible), 83 guests, and 2 robots.
Topics128,139
Posts1,056,754
Members48,454
#1607575 07/10/2026 7:17 PM
What size socket or wrench fits the big nut that holds the wheel cylinder to the backing plate? Asking for a friend. 😉. Actually, I injured myself trying to get it off with a crescent wrench. 😥
It’s been 20+ years since I worked on any drum brakes…. Thanks!
Professional Novice
Actually that big nut is for the brake shoe anchor pin used for major adjustment (centering) of the shoes. It's a 15/16" hex. Wheel cylinders are secured by two 1/2" hex head bolts.
That's the sizes on my '51, which should have the same Bendix brakes as a 66 C10.
Crescent wrenches are known for drawing blood. frown
Frank was probably using a metric Crescent wrench.
Yeah, that. grin
Well, that makes sense. Thank you!
Professional Novice
Well… that’s not correct. The rear wheel cylinders are attached by two bolts through the backing plate. But the front ones must be mounted by the anchor pin. And the hex measures 1.137”. So I guess a 1-3/16 socket will fit it. I will have to buy one.
Thanks for all suggestions. 😊
Professional Novice
Frank, you are correct about the wheel cylinder mounting. I didn't look close enough when I checked on RockAuto for the wheel cylinders. Does the rear anchor pin that's separate from the wheel cylinder mounting use a 15/16" hex nut?
It seems like that front anchor pin mount would actually restrict the ability for it to move in relation to the backing plate. The hole in the '51 backing plate is elongated vertically to allow the anchor pin to move.
BTW, RockAuto has AC Delco wheel cylinders for about $12 each.
I don’t know about the rear nut. I haven’t worked on a rear brake on this truck yet.
Thanks for the tip on wheel cylinders at RockAuto!
Professional Novice
I got it apart. And it’s not a nut, it’s the anchor pin. 6-pt impact socket, breaker bar and a generous cheater pipe got it out. It really helps to have the right tools.
Thanks for all responses.
Professional Novice
