0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 221 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 221 | just went to my O'Riley's for a pan gasket, and was asked what thickness i wanted? what with this? i've been working on these inlines sense the late 50s and never heard of such a thing. Jay D. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I doubt that O'Riley's has a pan gasket set that will fit much less have choices of thickness. I have been building GMC engines for almost 70 years. The only choice around may be Best 28011. There are eBay sellers that sell them. Do a search for 28011 gasket set. | | | | | Joined: May 2015 Posts: 11,084 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,084 | Actually O'Reilly's website shows 5 different thicknesses. All are special order at least where I am.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,469 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,469 |
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Sep 2009 Posts: 5,943 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,943 | I did a bit of web searching for the FelPro OS3472C set Bill mentioned. All the sellers listed except one, which doesn't appear to be well known or give much detail about themselves, indicate the set is out of stock. A further search of crenwelge's suggestion on Best Gasket Set 28011 located Vintage Gaskets out of Alabama indicating they have them in stock. Alternatively, a search of the Best Gasket site and their authorized retailers shows The Filling Station FS-412 which appears to be available. There may be others, ut didn't have time to search further tonight. Hope this info helps.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2013 Posts: 221 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 221 | any idea why there are different thicknesses??? Jay D. | | | | | Joined: Sep 2009 Posts: 5,943 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,943 | jay d - No idea that I can figure out.  After going back and looking at the O'Reilly's multiple offerings, even though it says its listed to fit your 270, a closer look at their full application lists for each of the products shows they supposedly fit engines that have no relationship to the GMC inline 6. Listings included fitting GMC V-6s, Chevy 261s, Chevy V-8's and so on. None of the products pictures match the design of the 270 oil pan gasket either. I seriously doubt that what they offer is worth chasing your tail on.
