2 members (Hotrod Lincoln, mo2cyl), 380 guests, and 5 robots.
Topics128,158
Posts1,057,025
Members48,460
#1594615 12/23/2025 12:20 AM
I haven’t posted in a while, but I just started getting back into this truck after relocating. Right now im going with Ipe for the decking, and well, I had some tool boxes probably a few other things as well. Will post some more pics later on.
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
AD Addict & Tinkerer
Nice job on the deck frame. Couldn’t help to notice the Detroit Diesel placard on the hood. Nice!
Phil
Project Journals
Stovebolt Gallery Forum
U
U Offline
Looks like a good start.
~ John in Utah
Here We Go
Follow in his DITY Bay
I like it. H... for stout no doubt. Keep up the Great work and keep us in the loop!
RonR
RonR
1970 340 Duster
1964 CJ5
Update, got the Ipe wood down, (1st photo) milled and epoxied stainless studs on the underside. Cut up a bunch of aluminum plates that catch the channel almost like a step clamp. I figured it would be much easier than drilling through the channel itself. 2nd photo I treated it with “Cabot Australian Timber Oil.”
1950 Chevy 3800
Added toolboxes as well
1950 Chevy 3800
U
U Offline
Turning out to be a good work truck!
~ John in Utah
Here We Go
Got all the decking bolted down today in the 100 degree Florida weather. I also added a clearance lights on the side. The next thing I may end up doing later on is some sort of bolt on grate for the headache rack. But for now, I’m gonna get tags on it shortly and take some more photos.
1950 Chevy 3800
Is there another angle at the joint between the third and fourth boards in from the side? In other words, does the rear of the bed frame have five sides and not three? Or is that just a trick of the camera in the first picture?
1950 Chevrolet 3100 (Ol' Roy)
They sure is, I can’t remember the exact angle. I was kind of going for the look at some of these newer welding truck have with their flatbeds
1950 Chevy 3800
U
U Offline
I see the bolts underneath, but not visible on top. How did you secure the boards?
~ John in Utah
Here We Go
Yes, theyre stainless carriage bolts that are epoxied in. We used the router to make the T slot and the aluminum plates capture the C channel, think of it like a step clamp.
1950 Chevy 3800
