2 members (TexasJim50, Joe W),
38
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | 12K lb item about an 8 foot square foot print, going 1800 miles.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Sep 2009 Posts: 5,775 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,775 | Just a thought, but you might get more responses if you can provide more details.
From where to where (generally speaking).
"8 foot square foot print" doesn't give anything in the way of the height of the item. An extra tall item (if over 108" high) will require transport on an open to the elements trailer (and tarped for weather protection if needed), or a specialty trailer configured to enclose a taller than that item. 8 foot square would just fit width wise into most standard dimension 53' enclosed trailers, but leaves you doing something different if the item extends beyond the 8 foot measurements anywhere above the base foot print.
With an item that size/weight, you'll need to consider loading/unloading of the item as well, unless you have the equipment to handle that process yourself (either loading or unloading as the case may be).
Your best bet might be contacting some commercial carriers that service your area for cost quotes.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Blue Lane Freight is a trucking company owned by Fastenal. They will ship palletized dry freight from one Fastenal store to another. Try contacting them with the dimensions and weight of your item for a quote. I'm not sure if they service your area or not, but it might be worth a try. Jerry
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Its a machine tool. I would not want to have to pick it up at a fastenal.
| | | | | Joined: Aug 2001 Posts: 3,587 Moderator | | Moderator Joined: Aug 2001 Posts: 3,587 | Truckrolet I have to also ask for more info to help you. From where to where? Will the seller load it? How will you unload it and get it in your shop? Jerry is a pro Machinist and I have been around machine tools since I was sixteen. Mostly the bigger ones. Sounds like it could be an older Cincinnati vertical mill.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Don, maybe he should do what you and I do- - - - -hook up the truck and trailer and go get the machinery ourselves. That's how I'm planning to get a 20 foot CONEX container full of engines, and a big lathe from Texas to Tennessee. The 24 foot gooseneck I just bought, and my F-450 flatbed truck should handle it nicely. I just hauled a big flycutter cylinder head mill and a power jet washer on my 18 foot bumper pull trailer, with a combined weight of around 8K pounds. Jerry
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Its back east I'm not giving specifics here. Owner can load it. I can unload one way or the other.
I would not waste time or $ on something like a Cincinnati vertical. Vertical mills are way to limited on what they can do, unless its a turret mill, yeah not a hogging machine but very universal. One of my favorite mills back when I did that work, was a Number 5 Cincinnati Verci Power with a dependent universal head on the over arm, and 50 hp, and yes used that HP at times too .Steel plate, 6 inch wide cut, .5 deep, and 30 ipm if memory is correct, horizontal spindle. Me too since 16 or so, at high school, and voc tec.
Great Jerry how much would you charge? LOL I do not have a truck capable of going to the store with its also a stinking ford f250.
