| | | Forums66 Topics128,188 Posts1,057,218 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Question- Is the seat the same for '48-'54? If not, can someone please give me some identifiers by year? May I assume Chevy and GMC used the same? Thanks, Brian | | | | | Joined: May 2015 Posts: 11,165 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,165 | The only thing I know of being different is the seat adjusting mechanism. Earlier AD trucks use a cable system, that later changed to a rod connecting the two sliders. Although the Master Parts Catalog lists the seat springs assembly for 54 as different, but I don't know what the difference is.
Last edited by klhansen; 07/01/2026 9:36 PM. Reason: added clarifying info in bold
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | OK, yeah, I just found it. That change was in 1951. Thanks! | | |
