1 members (Otto Skorzeny), 201 guests, and 3 robots.
Topics128,091
Posts1,056,387
Members48,442
I was assuming the slinger went on AFTER the gear and cupped towards the front of the engine. It wont fit that way! I have a Thickstun timing cover and the slinger is hitting the cover on the inside. SO HOW DOES IT GO? It can't fit cupped towards the gear. I have a General Motors GMC truck manual, BUT it says nothing about the slinger. Its possible that it might not be a part of this engine, as it was a basket job. Could the slinger be from something else????
Jay D.
Jay, Let us know what engine you're working on. That would help the guys answer your question.
If you go to your profile and add your truck info in a signature, you wouldn't have to type it in when you post.
Thanks, I corrected the post.
jay d - I just leafed through the engine section (8) of a 1955 GMC Models 100-500 Shop manual. I see nothing related to a "crankshaft oil slinger" in the instructions or diagrams.
Post a picture of your "slinger" so we can further consider what it may really be please.
~ Dan
1951 Chevy 3 window 3100
None of the 4 GMC Master Parts Books (covering 1939-1960) that I have show an oil slinger at the front end of the crankshaft of any 228, 236,248,256,270 or 302 GMC inline 6. My 302 doesn't have one.
There is an oil slinger at the rear of the crankshaft between rear main bearing and the rear main seal. The cavity that the slinger rides in has a drain hole in the bottom. This slinger is not removable from the crankshaft. It is machined from the raw crankshaft casting.
Either the slinger you are worried about is a part specific to the Thickstun timing cover you have or one of your buddies dropped a slinger from some other engine in amongst your GMC parts as a prank.
THANKS, i think it came from another engine. as i said this engine was a basket case completely apart and could have been a mixture of who knows!
Jay D.
Since you're going to need a spacer between the timing gear and the balancer you're planning to use, a little bit of creative metal butchery on a lathe could create a slinger, if you want to go to the trouble to make one.
