5 members (latroca52, Woogeroo, Mike Burns, Rusted Nut, TS3600), 68 guests, and 3 robots.
Topics128,188
Posts1,057,334
Members48,469
#1606597 06/27/2026 4:38 AM
I had some custom built made wheels made for my coe and when put on the tire balancing machine we could see motion so I did my best to measure the runout. I got 25 thousands on the face and 100 thousands on the rim. Is that way out? I don't know what the tolerance is.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I asked AI and it said 25-50 thousandths is acceptable for both radial and lateral runout. Depending on where you're measuring (didn't really understand your 100 thousandths on the rim), but if you meant the very edge, that's not as critical as the bead seating area.
[on edit] unless you have aluminum wheels - those should be tighter - 30 thousandths maximum.
Almost 1/8" runout is WAAAAYYYY too much! Does the manufacturer offer any kind of warranty?
