5 members (Phak1, WICruiser, dt235sd, GMCJammer51, Goach2), 41 guests, and 0 robots.
Topics128,196
Posts1,057,395
Members48,471
Does anyone have the Original Delco Remy part numbers handy for a 1957 235 for the following:
Cap
Rotor
Points
Condenser
Thank you in Advance,
Todd
1950 Chevy 3100
Original GM part numbers (Not necessarily Delco-Remy)
Cap - 1924248
Rotor - 1924245
Points - 1924571
Condenser - 1928111
From the 1929-1957 Master Parts Catalog.
Kevin,
Thank you. Looking for the Delco Remy numbers. I was given a box of parts. Seeing if I can use any of it.
Todd
1950 Chevy 3100
Those GM numbers may cross over. RockAuto sometimes has cross-over numbers.
The GM Cap # comes up with a STANDARD MOTOR PRODUCTS DR428
OEM / Interchange Numbers: 12338676, 1924247, 1924248, 1931512, 3141430, J3141430
Todd - A web search located this archived original 1970 Delco Remy Catalog 1A-100-1 that covers 1946-62 vehicles.
A search under the Chevrolet Truck 3000/4000 Series 6 cylinder for 1955-59 listing shows the following Delco-Remy Part Numbers for your 1957 235 application (screenshot below):
Cap - D306
Rotor - D405
Points - D105P
Condenser - D203
Happy hunting!
~ Dan
1951 Chevy 3 window 3100
Figures that Dan would have the info. Him being the parts hunting guru. grin
Thanks Kevin. smile
What's crazy is I did a web search to find the resource book, forgetting that I have several of these original Delco-Remy Catalogs sitting in my Stovebolt Library - duh! dang
Oh well, in the end the information has been shared and hopefully helps Todd and any other Bolter searching for similar info in the future. wink
~ Dan
Dan,
Thank you.
Todd
1950 Chevy 3100
