Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Wheelie, Rosco, greenie-reddy, 1 invisible), 117 guests, and 1 robot.
Topics128,291
Posts1,058,588
Members48,492
Page 3 of 3 1 2 3
7
7 Offline
Man, sorry to hear that. If it were mine, I would leave the engine in the truck and pull the heads. The 355 that I built years ago was drinking oil at an alarming rate, when I was farming out the machine work originally, I took the heads to a shop that was recommended, bronze guides, 3 angle grind, umbrella seals. I pulled those heads and replaced them with another set of cast iron medium valve units but had another machine shop do the head work. Along with the head swap and pulling the big block oil pump and putting in a small block normal capacity pump, the oil consumption problem disappeared.
I considered leaving the engine in the truck but working over the fenders to remove much, especially heavy things like the heads doesn't sound like a plan. I may take the carb and intake off to check for oil being sucked in from the valley (wishful thinking, I know) but that would be the limit I think.
1949/50 3600 Project
Follow in Project Journals
If you still have the 235 , get it rebuilt. At our age , who cares about how fast we get there. Most important ...how it sounds.
Making a bunch of noise but still cannot go faster than a hyndai, seems silly.
Only thing I pass out here are tractors and amish buggies.
Or buy a crate 350 and sell the 383. Quicker that way.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I don't have the 235.
I built the 383 and need to understand what I did wrong so no plans to replace it and I am not in any hurry.
RLB Offline
Sorry you’ve got to deal with pulling the engine but I’m with you. I’d want to know what went wrong.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
I finally decided to determine what my approx fuel consumption is and based on one fill and roughly 100 miles I calculated it is in the 8 mpg range. I knew it wasn't good, but didn't expect it was that low, so I am wondering if my oil consumption problem may be associated with excess fuel washing down the cylinder bores resulting in bore and ring wear.
The engine has always started and run well, generally starting without the aid of the choke so I should have suspected it was pretty rich and I do not expect the fuel consumption to be very good.
If the oil problem is associated with excess fuel is it likely that the 1000 miles I have on the engine has worn it to the point that it needs to be honed and new rings installed or can I lean out the carburetor and avoid pulling it out and apart? I know there are a lot of piston miles traveled in the bores for 1000 miles but if I can avoid pulling the engine out/apart it would be desireable.
Regardless I need to detmerine how best to get the carburetor calibration closer to desired (whatever that means). Is there a good way to determine the proper jetting other than trial and error? I do not have an exhaust analyzer but may have a shop nearby that could help with this if that is the way to go.
I should add that the engine runs very well, pulls good through the rpm range with no bogs or indications of being too rich. The tailpipes have black soot and while it has been a while the plugs indicated (see earlier post in this thread) it was running a little rich but not so much so that they are sooted.
7
7 Offline
What carburetor are you running? Make, CFM, spread bore/square bore, vacuum/mechanical secondaries, air filter size, intake manifold style?
RLB Offline
Get a A/Fuel Ratio gauge from EBay or Amazon. Hardest part of install would be welding the bung for the sniffer (sending unit) in one of the exhaust pipes just in front of a muffler. I would think a.ratio in the 13 or 14 to one range would be what you’re looking for.. personally, I believe if it’s running so rich that it’s washing the.cylinders then it would probably be diluting the oil as well. You would be able to smell the gas in the oil.
HiPo
I'm running a Holley 3310, I believe it is 750 CFM, has vacuum secondaries, air filter is a smaller element after market (I need to measure the size), the intake manifold is an Edelbrock Performer 2104. The carburetor was rebuilt by me before being installed but I do not seem to have a record of the main jets in place.
There was not evidence of gas in the engine oil so I suspect that was not the problem.
I pulled the intake manifold and there is no evidence that there was oil coming in from the valley so I pulled the front clip and plan to pull the engine for dissassembly and inspection.
The good news is all the bolts associated with the front clip as well as the engine were recently installed so not fighting hardware like a normal vehicle dissassembly process.
November is a busy month so while I plan to get the engine out and the heads off I doubt I will get much further until after Thanksgiving.
7
7 Offline
The Edelbrock 2104 and the Holley 3310 should be a workable combo, primary jets should be 70-72, you might go as small as 68's. Make sure the secondary throttle plates are fully closed at idle. You might want to double check the float level on both sides. If you are at all concerned about air restriction, go as big as you can on the filter, restriction will richen the A/F mixture. When you built the engine do you recall what compression ratio you were shooting for, and what size intake valves, combustion chamber c.c.?
The air filter is 11" dia by 2" tall, so on the small side. I believe the combustion chambers are 64cc and I calculated the CR to be 9.7 static, 8.1 dynamic. I have the Comp XE268H-10 cam.
I pulled the engine out and removed the heads. Generally the plugs looked worse than previous (more deposits, darker color) except #8 that was very white (need to investigate potential coolant leak into #8). There was nothing noteworthy about the combustion chambers or pistons, and bores still have some of the cross hatch. Cylinder #1 looked about the worst for deposits on the plug so I may pull the intake valve to evaluate the valve to guide clearance.
Until I pull pistons and check the rings it is a guess but I suspect that the rings are stuck (not free floating) in their grooves and it may be a result of the long delay between engine assembly and first firing ( roughly 3 years).
I'd say that 1, 5, and 7 are the smokers. Otherwise, those valves don't look terrible. Either intake guides or rings would allow oil in and make it smoke.
The pistons are out and the compression rings are free in the piston grooves, the only questions relate to the oil control rings that seem to be much closer to the piston diameter but do seem free to move in the grooves. It is not obvious if the compression rings were installed correct side up or if they are indeed intended to be positioned one way or the other.
The cylinder bores look pretty good with a fair amount of the original crosshatch still eveident.
I'm continuing to evaluate the parts but a bit disappointed that there is not an obvious cause for the high oil consumption and smoking that I can idenitfy and correct.
7
7 Offline
Push the rings into the bore with a piston so the rings are square to the bore, measure the end gap, hopefully that will tell you of any abnormal wear. I think the oil rings can go in either way. When you pulled the heads, did you look at the underside of the valve head through the ports, wondering if oil is cooking on the valves due to guide/stem/seal leakage?
I measured the compression rings, top ring end gaps were 0.023-0.025; second ring gaps were 0.019-0.022. The top rings did not have any orientation markings, the second rings had a "TOP" orientation mark and they were placed in the piston ring grooves with the "TOP" facing the piston crown.
I looked at the intake valves and removed one as they were all similar, picture attached. Given the amount of oil deposits on the valve I am wondering if I pulled the trigger too quickly on this being a piston ring/bore problem. I am beginning to think it is a PCV problem and I need to add a catch can or something similar to my PCV system to separate oil that may be coming through that pathway.
My current thought is to get new rings and gaskets, replace the intake valve stem seals, reassemble, and develop some type of oil separator system for the PCV.
It may be crazy but I am considering not touching the cylinder bores or replacing the rod bearings.
7
7 Offline
If you are going to put new rings in, you will want a quick hone job. Bearings should all be good unless you find something that indicated trouble. Do you have the ability/tools to measure valve guide and stem clearance, the intake valve looks like it is sucking oil down the guide or possibly the PCV system as noted.
I can measure the valve stems but don't have a good way to measure the guide IDs. Once I remove the existing vale stems seals I will see if I can guesstimate the clearance.
Does anyone have insight regarding how to put together a PCV catch can system to seperate oil that may be coming from through that system?
To start with, you should not have so much oil vapor that you need a catch can on normal operating PCV valve system. The early 283's used a can under the intake to limit oil usage, but that was just the start of the PCV usage. A simple baffle is all that was used after the can was discontinued. The inside of intake should be coated with oil if the PCV sucked it in.
A quick hone, new rings, gasket set, and valve stem seals should get you back on the road. Use a dial indicator on the valve stem while you push and pull on the stem inline with the indicator, this will give you an idea of how tight or loose they are. Could be the seals just dried up from not being used for three years, rubber is not what it used to be. I pulled a Pontiac apart that was using oil real bad, found all the intake seals stuck to the stems and riding up and down as the valves moved. On the down stroke, they acted like scoops grabbing up oil and shoving it into the guides. They were the wrong size to start with.
Keep all the bearings in order and on the same rods / mains, no need to change out new parts. A quick wipe with a clean towel and some assembly grease is all thats needed. Careful with the rear main if you pull the crank to hone. If you don't pull the crank, pack the bottom of the engine with towels to keep the hone oil in the cylinder, then super clean each cylinder as you go. It won't take much too rough up the bores a little, the new rings will need something to bite into.
Did you use Moly rings or cast iron? Moly is all that I would consider.
I did not detect an oil film on the intake but I am not sure if it is a mist if it would be obvious. The stem seals seem to be staying put but I plan to change them regardless.
I like the idea of measuring the clearance with a dial indicator.
I was hoping not to pull the rear main seal and crank as it appears to be dry. I appreciate the advice on how best to handle the hone with the crank in place.
The rings came with the stroker kit and I believe they were Moly. I plan to use Moly rings this time just to be sure.
I have the rod bearings in place and in order so they go back in the same location.
7
7 Offline
With the engine on the stand and all of the piston assemblies removed, I would not hesitate to pull the crank and cam out, any machine work/honing will be dirty and in my book too risky not to clean the bare block thoroughly afterward. The rear main seal will be included in a complete gasket/seal kit, might as well go all new seals. I agree with Joe H on the PCV system, there should be no need to alter the factory system if the plumbing is correct. You could check out the catch can options at Summit or Jegs but that engine shouldn't need any. Just my 2 cents.
I buy from these guys, https://goodson.com/products/38-829-45-stem-seal and only use this type of seal made from Viton. They have worked good for me.
Thanks for the lead on a quality valve stem seal. I know they come with most gasket sets but I suspect that the ones in the sets are selected based on lowest price, not best performance.
I measured one intake valve to guide clearance using a dial indicator and got 0.005 which I believe is okay. The seal I removed prior to measuring is very loose on the valve stem so I think I may have identified the main problem. I will check all the rest for stem to guide clearance and inspect the removed valve stem seals but given the visual appearance of the valves through the ports I anticiapte they will all be similar.
Too bad I pulled the engine and the pistons out rather than just replacing the valve stem seals with the engine in place but I'm glad I did check everything out rather than assuming everything was put together correctly.
I suspect that the stem seals dried out between build and initial operation and basically stuck to the valve stems such that they wore quickly. The ID of the seal that should be riding on the valve stem has a white plastic apperance leading me to believe the rubber material that was intended to be between the plastic and the valve stem is totally gone away. As a result the engine has been operating with essentially no seals and I shouldn't be surprised it was consuing oil as a result.
I hope that's it.
I thought you pulled the valve covers off after all this began and looked at the valve train. I'm probably confusing it with another thread.
1950 Chevrolet 3100 (Ol' Roy)
I`m trying to follow. Its sounds like the trouble is the engine sat for too long after being rebuilt?
A freshly rebuilt engine that has sat unused for years can still be safely started and run, provided you inspect it and re-lubricate
the internal components first rather than cranking it dry.
~ BD.
7
7 Offline
Depending on the brand and type of valve seal, the white plastic is typically Teflon, the rubber should stay with the guide and the valve should ride up and down within the Teflon.
If the white is teflon (probably is) then it is worn a lot as the seal is no where near close to being snug on the valve stem.
Otto, I did inspect a valve seal early on but only visually to see that it was in place. I should have pulled the seal off the guide and checked it but didn't (my bad, and I'm paying for it).
Guitarplayer, I did pre-lube the engine by running the oil pump with a drill prior to starting and if the seal is just worn out it's my bad for not checking them more closely when I originally put it together. I do recall using a sleeve to protect the ID of the seal when installing the seal over the end of the valve so they must have been tight at that time, or at least that is what i recall.
The information to date is based on one valve and one seal so I will need to update after I have inspected all 8 intake valve to guide clearance and seal conditions. Given the deposits on the intake valves I am hoping that I have found the main source of the oil consumption and smoking issue that started this discussion.
Okay, I pulled the remainder of the intake valve seals and the rest seem much better for fit on the valve stem. Definitely a fair amount of difference in the level of deposits on the intake valves. Some valves have a relatively thin even coating where others have a relatively thick, almost chunky appearance to the deposits. There is not a great correlation between the valve deposits and the spark plug deposits but similar trends. It is hard to tell if the thin even layer of deposits is from oil or from fuel.
Valve to guide clearance seems to be 0.005 or less on all the intake valves with most not having any real feeling of clearance when trying to flex the valve stem side to side in the guide, the first valve removed feels to have the most clearance and is the one with the seal that seems loose on the valve stem. The measurement of 0.005 I am getting is above the keeper grooves so more movement than if it was at the top of the guide.
I'm feeling less confident that the stems seals were the major source of the oil consumption but there was clearly oil from some source going through the intake tract resulting in the deposits on some if not all the valves.
I have pretty much run out of time to work on this until after Thanksgiving due to other plans.
7
7 Offline
I was certainly surprised when the head swap corrected the oil consumption on the 355, with the high oil use I thought it would be a combination of rings/bore/heads. You may find it is just the heads.
Those teflon seals are for race engines that need more oil on the guides. Go with the solid rubber Viton, the sets from Felpro work good also. I have seen a couple sets of the teflon type leak pretty bad. A good seal will hold a valve in place, but not so tight you need to force it to move. You should have to tug on them to get them off the stems, if not, they were to loose. I have the heads cut for the type I linked ( positive type ), it usually takes a deep socket to drive the seal on to the head, and the head and seal need to be dry so they " stick " to the iron along with the spring clamp pressure.
To further muddy the water the valve stem seals on one head (1,3,5,7) were different than the other (2,4,6,8). The odd number cylinders had the seals with the teflon like material and only one retaining ring (on the guide end) whereas the even number cylinders had a rubber (viton?) appearing material with 2 retaining rings - one on each end. There was not a clear correlation of good vs bad valve deposits to the seal type but in general the even number cylinders valves and spark plugs looked better.
Current thinking is to install new viton type stem seals on all after cleaning up the valves.
I wonder if one type was supposed to be for intake and one for exhaust. the sealing requirements are different.
Page 3 of 3 1 2 3
