2 members (2-Ton, JW51), 67 guests, and 4 robots.
Topics128,055
Posts1,055,783
#1606472 06/25/2026 5:40 PM
What is the best practice for setting the valve clearance? The shop manual says .012” intake and .020” for the exhaust.
Over the years users have often found that variations to the original specs work better.
INTERRESTING i'm just now assembling a 270 and was wondering what would be a good place to set them at cold for a first start up? i have a RV grind cam that i don't know the specs to and also going to run a turbo. i do know its touchy my other 270 with the roots blower and blower cam. i got the lash a little to tight, it still had lash but wouldn't run. loosened them up and it runs like a freight train.
H Online: Content
Degree the cam. The height of the clearance ramp will be very obvious- - - - -it's an area of gradual lift just as the lobe shape transitions from the base circle to the beginning of the lobe lift. Exhaust clearance ramps are usually higher than intakes, due to the heat expansion of the exhaust valve stem. Just about all the cam grinding companies publish detailed instructions on cam degreeing on their websites or paper catalogs. I learned how to degree cams by reading the 1954 edition of Ed Iskenderian's "Top Tuner'' Tips".
