3 members (Gdads51, JoergK., 1 invisible),
91
Mod | | | Forums66 Topics128,181 Posts1,057,150 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2023 Posts: 24 'Bolter | | 'Bolter Joined: Apr 2023 Posts: 24 | Freshly rebuilt starter and new 168 tooth flywheel. I’ve got too tight of clearance and starter gear sometimes will not mesh. How do you shim the three bolt starter away from the flywheel on these bellhousing style starters? | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | There is a metal plate that is installed behind the starter and attaches to the front of the bellhousing on V-8 applications. If it is missing, it may be the problem. Fred
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Check the runout from the crankshaft centerline to the bearing retainer hole in the bellhousing with a "last word" dial indicator.. I believe there are offset dowel pins available to correct misalignment between the block and the bellhousing. Jerry
