7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible), 56 guests, and 3 robots.
Topics128,176
Posts1,057,122
Members48,463
Freshly rebuilt starter and new 168 tooth flywheel.
I’ve got too tight of clearance and starter gear sometimes will not mesh. How do you shim the three bolt starter away from the flywheel on these bellhousing style starters?
1957 Chevrolet 6700 (31' School Bus)
in the Gallery Forum
1975 Chevrolet G30 Van Hightop (ClassB RV)
R Online: Content
There is a metal plate that is installed behind the starter and attaches to the front of
the bellhousing on V-8 applications. If it is missing, it may be the problem.
Fred
Check the runout from the crankshaft centerline to the bearing retainer hole in the bellhousing with a "last word" dial indicator.. I believe there are offset dowel pins available to correct misalignment between the block and the bellhousing.
