| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | Have tried two or three valve spring compressing tools and they are either have a throat that doesn’t reach or the clamping won’t compress. Recommendations please. Auto Zone O’Reiles Habor Freight don’t have the tools I need | | | | | Joined: Dec 2025 Posts: 16 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 16 | OTC 4572 worked for me. Believe Harbor Freight sells a similar version under their Maddox brand. | | | | | Joined: May 2015 Posts: 11,080 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,080 | I tried one from Amazon This one won't work and wound up sending it back. It was the style that clamps around the head from the valve head to the spring keeper, but it didn't have enough leverage to compress the springs (either that, or my grip strength is failing me - no other evidence of that though.  ) I don't recall what I finally did to get the head disassembled - may have rented one from O'Reilly's.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | Khansen: I had the same experience with the same tool I purchased from Amazon and just returned it. dt235sd: the tool you suggest looks promising. I’ll have to see if it’s available. | | | | | Joined: Mar 2014 Posts: 4,502 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,502 | I've used one like this for over 50 years. Always works well: https://www.summitracing.com/parts/sum-906800You might want to look for the slightly larger one...I think that one goes up to 1.32" and there's another one that goes up to something like 1.7".
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | Jon, I’m assuming you used it on a 216 and or a 235 engine? I had seen these at local auto parts but was unsure if it would work on a 235. | | | | | Joined: May 2015 Posts: 11,080 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,080 | Texas, the 216 and 235 valve setups are essentially the same. So a spring compressor that works on one should also work on the other.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | I used one like this on John's 261 a couple of months ago, when my air-powered spring tool bit the dust after 40+ years. Worked like a champ! www.ebay.com/itm/158009533825?Jerry
| | | | | Joined: Dec 2025 Posts: 16 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 16 | Jon, I’m assuming you used it on a 216 and or a 235 engine? I had seen these at local auto parts but was unsure if it would work on a 235. I used that style as well back in January when I replaced valve stem seals on my 235. It was a little difficult to operate, but it worked. Be sure the valve doesn't fall out on the concrete floor. Some have a 3/8" female square on the end so that you can use a ratchet w/ extension to turn it. I suggested the OTC C-clamp type because I used it as well and found it easier to use. I had to add something to gain a little more leverage (can't recall what that something was at the moment?). That's why I thought the one from Summit might be ideal, but I have no direct experience. Plus its $100, so not inexpensive for occasional use. This was my first time removing valve springs; I'm sure practice makes perfect after a while! | | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | One thing that helps is to hit each valve retainer with a hammer just off to the side of the valve stem, this breaks the taper retainers loose so it comes apart much easier. It doesn't take much of a hit so go easy. The springs don't have a lot of tension on them but over time the tapered retainers really get tight. | | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Set the head on a couple of wood blocks, find a socket or piece of pipe that fits the spring cap. Tap with hammer to break the cap loose from retainers. Have a magnet handy as retainers may pop out.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2014 Posts: 4,502 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,502 | Yes, I've used that compressor on lots and lots of engines. Including a Briggs & Stratton 11hp horizontal engine for a generator. You just have to turn the wheel until you can slip the two valve keepers out or replace them when you go back with a new spring. Really easy to use once you get the hang of it. One neat thing about it is if you ever suffer a broken spring (I've had 3 or 4 on 235s), you can change the spring without removing the head. Just carefully get the piston up to the top of its stroke.
| | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | | | | | | Joined: Mar 2021 Posts: 258 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 258 | Jon I purchased the same tool on Amazon and the “star” adjustment knob popped off after three springs removed. I modified it by adding a screw and washer on top of the adjuster. The keys were so fused to the spring retention washer that it was troublesome removing the springs. | | |
