2 members (KEVINSKI, JW51), 79 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#1606209 06/22/2026 11:56 AM
Attached is picture of the “land” of the cylinder head . It’s approximately 0.024-0.030. Is this “land” dictate how much more can be shaved off the cylinder head surface before it needs to replaced?
Moderator, Electrical Bay
Maybe...and it depends. You usually can mill the head .030 to maybe around .040" but that assumes it hasn't been milled before. I always stop when the least amount of milling produces a flat surface. Not good to go too far and today you can not easily find the thicker (and in my opinion better) copper sandwich head gaskets. The ones you get today will be thinner.
~ Jon
Here is an image of one that was milled about .010~.012 around 50 years ago. It is still fine.
~ Jon
