1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
I am helping a friend with his 46 we need to see a picture of how the pedal return springs attached
It’s the original 216 bell housing etc
I have a bracket and the 2 springs
Pictures please
Thanks 🙏
52-Mobil - Take a look through all the info and pictures in this previous thread. You can see all the details on the both clutch and brake pedal return springs for a '46, including links to some part number info if that's needed. wink
~ Dan
1951 Chevy 3 window 3100
U
U Offline
Yes - That thread was when I was trying to figure out how to install the brake and clutch springs. But then I found out I needed to install the engine side pan with the little "Z" bracket to hold the brake spring and extension wire that goes to the clevis pin on the brake master cylinder. Also, the same return spring is used for both.
~ John in Utah
Here We Go
Follow in his DITY Bay
