1 members (Wooley), 88 guests, and 3 robots.
Topics128,096
Posts1,056,488
Members48,444
#1606160 06/20/2026 12:54 AM
This frame has been presented to me as compatible with a '53 Chevy 3100. I know the wheel hubs are not standard since the tires are 235 75 R15.
Can anyone identify it from this picture? I have different angles if that helps.
Advertised as a 47-54 Chevy 3100 frame
In a world where you can be anything, be kind smile
It kinda looks like it Tinker, but I'd suggest more pictures are needed to better confirm. That and get them to measure the wheel base, which should be 116" (see attached screenshot from the 1953 Chevrolet Truck Data file).
~ Dan
1951 Chevy 3 window 3100
More pictures from different angles. The space is close to 116, but may be 115. Hard to measure by myself…
Frame pictures
The tube shocks make it a 1950 and later chassis. The rest of the pictures seem to confirm it's an AD 1950-54 3100 frame. The only other observation I would make is the condition of the front crossmember being in less than good condition on the rear ridge section which is where the engine front mount goes. That's going to require some repair or a replacement to properly support the 6 cylinder engine (if that's your plan?).
~ Dan
The shocks make it 1950 or later, like Dan said. The higher hump over the rear axle make it 1953 or earlier. In 1954, the flat bed sides and deeper floor required less of a hump over the rear axle.
So from those two things, it's a 1950, 1951, 1952 or 1953 frame. Can't get any closer than that.
The tire size doesn't define what the wheel hubs are, as there are lots of rim sizes that will fit on the 6 lug pattern.
Thanks for the great help! Part of my 5 year plan is to go slowly and get it right👍🏼
'51 to '53 based on the spare tire mount, high arching frame hump. and the type of rear motor mount crossmember.
'50 and earlier had the slide-out spare tire carrier. This one has the swing out style.
'54 and later had angled rear motor mounts on the crossmember, and lacked the bolt on transmission crossmember.
