3 members (TUTS 59, ShopRag, 1 invisible), 106 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
#1605771 06/16/2026 7:13 AM
Got to a car show yesterday (without my truck) and saw some nice vehicles.
A nice 55.2 or 56 1/2 ton and a 1953 GMC panel.
24601
Kevin -- Always fun to go to a show that actually has interesting vehicles to look at, instead of just a bunch of late model stuff showcasing added on chrome crap, loud stereos and computer performance.
Beautiful panel truck!!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Some really nice local trucks there Kevin. Will be nice when yours can join them in the future. I agree on John's assessment of the "Beautiful panel truck!!" thumbs_up
~ Dan
1951 Chevy 3 window 3100
Thanks for sharing pics of those beautiful rigs. Wish one had been full of COHO Salmon thumbs_up Oh and the interior shot of the panel wagon....wow!
Craig
Kevin,
Great pictures.
How soon until you are back on the road?
1950 Chevy 3100
Machine shop says maybe they'll be done assembling the short block next week. Then I have to bolt the rest of the engine together and install it. My target is the big show the first Sunday in August, if not before.
On a side note, I took a closer look at the engine bay on the GMC panel. Didn't recognize the carburetor - not a Rochester or a Carter that I've seen. @carbking might know.
Last edited by klhansen; 06/16/2026 7:41 PM. Reason: added zoomed in photo of carb on the panel
Great news.
That's a Zenith Carb..not sure model
1950 Chevy 3100
LOL! Yep says "ZENITH" right on the side, if I had just zoomed up far enough. Has a bowl drain valve, which is a new one on me.
Kevin - That’s not a drain valve. It’s actually an adjustable “main jet”.
“carbking” can better describe it and how it functions than I can. wink
~ Dan
OK, as I said, I'm not familiar with that Zenith carb model. I do recall that the Zenith updraft carb used on the Model A's had a fuel adjustment on them, incorporated with the choke. Pull for choke and turn for more fuel when the choke is closed. That could be done on the fly from inside. Just accompanied a Model A back from that show that had issues with the engine running too lean and backfiring. A main jet adjustment took care of that.
That is a Zenith model 28 (has the idle mixture adjust screw high on the back of the carb) or 228 (has the screw on the left side near the throttle plate, can't see either in this picture).
The adjustable high speed jet was an option for use higher than 6000 feet above sea level.
The really neat thing about it was that you left the original main jet in place, as shown in the drawing below from Zenith's overhaul manual for 28/228 carbs. That way you can revert to the fixed main jet by backing the adjustment of the adjustable jet all the way CCW.
I have one on my Zenith 228, but I've never been higher than about 2100 ft above sea level.
