1 members (stlcardinalsguy), 71 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#1605691 06/14/2026 9:31 PM
just starting to assemble my 270 GMC and i pulled the oil pump apart to clean it. and i got to thinking about the relief spring, back in the old days we use to stretch them or shim them a little with the idea it would boost oil pressure. i have some AN washers that are .06 thick and fit perfectly under the spring good or bad idea???
Jay D.
jay d #1605696 06/14/2026 11:07 PM
Moderator, Electrical Bay
Generally shimming the spring will not help with low oil pressure at idle...at least from what I've seen. It could help with oil pressure at higher rpms however...but how much? You're sort of guessing. Please don't stretch the spring. Not a good scheme. If you could find a new spring that might be better.
~ Jon
jay d #1605705 06/15/2026 1:29 AM
Just FYI, I tested a 270 oil pump 10 or so years ago and found the pressure relief valve started dumping at 57 psi.
jay d #1605712 06/15/2026 4:11 AM
I used to do a classroom demonstration on how to stretch a spring- - - - -grab both ends of the spring with vise grips- - - - -stretch it to 3 times its original length- - - - -use a pair of wire cutters to cut it into pieces 1/2" long- - - - -then buy a new spring!
Hotrod Lincoln #1605717 06/15/2026 5:43 AM
Good advice. LOL!
