Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 84 guests, and 3 robots.
Topics128,290
Posts1,058,566
Members48,492
Looking for a template and/or measurements from a factory-stamped rear fender that had the 3 sergeant stripes trim pieces.
Thanks.
LUKE
Luke - This is for the AD series Deluxe Suburban/Panel fender trim stripes?
~ Dan
1951 Chevy 3 window 3100
Yes--good catch. I just updated the title. Thanks.
Luke - From what I've found today and in the past, there is a picture in the 1947-54 Chevy Truck FAM, but it doesn't give any measurements or specifications on where to mount those pieces.
The couple of vendors I see advertising them, Jim Carter and Chev's of the 40's, say their kits come with instructions, but they don't offer them separate from the kits.
I think your only hope is to find someone that has them installed originally (for measurements), or has a copy of the installation instructions they would be willing to share.
Sorry I can't be of more help. frown
~ Dan
Really looking for measurements taken from a stamped, original rear fender.
I'd call Jim Carter and see if he can give you that information or copy a template or something.
1950 Chevrolet 3100 (Ol' Roy)
I have talked with someone both at Jim Carter and Class Parts of America. They do not offer this information or a template. They just provide some background information, generalized directions, and a few pictures. It is enough to complete the project.
However, the detail that I am looking for would make the installation that much easier, and more professional/precise, in my opinion.
This is proving to be a tough find here. If it were made available to folks in the hobby, I have to believe that it would be a hit.
FOUND!
thumbs_up
Can you post a diagram? Dimensions from edges as close to right angles as you can would work. Surveyors call them swing ties.
Like you said, I'm sure fellow 'Bolters would appreciate it.
back yard wrench turner
I did a short search for this info. Several sites had folks wanting to know the measurements. Fonz, you would be quite the Hero to those that are still looking.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I should be able to provide diagram/dimensions and other information this coming weekend. Just not in a position to do it until then.
I have a rear fender template that I would like to share, along with a few photos. I understand that what I did to my 1/2 ton truck is not for everyone. Note that the rear fender template came from an OEM factory stamped fender from a panel truck. It had to be slightly modified to fit the curve of the fenders on my 1/2 ton truck. You want to start with a level truck, and keep the stripes level as well. I also made a butcher paper template for the front fenders, based on measurements that were shared with me by another fellow hobbyist. He provided the dimensions from an OEM factory stamped front fender. The front and rear stripes are horizontal with one another.
Last edited by fonz8261; 08/10/2026 12:37 AM. Reason: add converted pictures shared via email
I’ll add to this,, here are pics I have saved..
Outstanding added information! thumbs_up
~ Dan
