3 members (Otto Skorzeny, Gray_Ghost, Phak1), 174 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
#1605223 06/05/2026 8:14 PM
Fuel gauge goes right to full when the key is turned on. Had the gauge assembly out of the truck very recently and refaced three of the gauges and installed a new (NOS) temp. gauge. Everything working fine except the fuel gauge, worked great before the new gauge facings were applied. Carefully marked the wiring prior to taking the gauge/speedometer assembly out of the dash so the install would go smoothly. Took the time to double check everything when it went back together, all wires went back to the same spot where they were taken from. I'm sure this kind of problem was discussed back in the archives someplace, but if anyone has a thought on it, please share.
Thanks, Tom
3800GUY #1605229 06/05/2026 11:06 PM
After tear down and assembly I had multiple issue with the fuel gage. After weeks of troubleshooting I discovered that painting the inside of the housing in Not Good. I removed the painted surfaces inside of the housing and all my fuel gage issues were resolved.
Hope this helps.
3800GUY #1605231 06/06/2026 12:33 AM
check your ground(s).
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
3800GUY #1607617 07/11/2026 1:56 PM
Texas,
How does the fuel guage mount behind the dash? Does it go fuel guage,back panel,, nut, then metal/cardboard divider part, connections,then nut? I am getting ready to install mine and I dont want to fry it.
HANK
3800GUY #1607620 07/11/2026 3:37 PM
U
U Offline
From this picture, it looks like the gauge is pushed through the small panel, then cardboard, nut and nut.
~ John in Utah
Here We Go
Follow in his DITY Bay
3800GUY #1607621 07/11/2026 3:47 PM
FWIW, I found the problem that I was having when I first started this post. Turned out to be the wire from the tank sending unit to the gas gauge was bad. Replaced it and we're good to go. Fortunately an easy fix.
Tom
Thank you UtahYork. It didn't look right when I removed it to replace the guage.
