5 members (55shaker, TUTS 59, 2-Ton, jmoore, dunfire), 108 guests, and 1 robot.
Topics128,048
Posts1,055,541
Members48,425
#1605182 06/04/2026 8:18 PM
Starting to reassemble the 302 (six)
When taking the cyl head apart , the intake ports had a metal ring about 1/4” wide as well as the head to manifold/ exhaust gasket.
The engine gasket set I bought does not have these metal rings,are they important?
They are in pretty bad condition but I can make them easily enough.
They're alignment rings to make sure the the parts mate properly.
1950 Chevrolet 3100 (Ol' Roy)
If they are the rings shown by 8.5010 in the page from my 1955.2=60 GMC Master Parts Book, making your own is easy. Like Otto says, they are designed to align the manifold to the head. I had 2 and needed 1. My FLAPS has a selection of short exhaust pipes, some straight, some adapting some diameter pipe to another. I found one that was just a little larger diameter than what I needed, cut a short piece (make sure it is short enough that the pipe won't keep the manifold from tightening up to the head), then cut a slot across the band so you can fit it tightly into the head.
I use a socket that's a snug slip fit into the manifold passage (not the counterbore) and use it as a forming jig to make my own alignment rings. A diagonal slot isn't a problem, since the rings don't have to seal vacuum- - - - -they're just for manifold/head alignment.
Thanks, sounds simple enough
