2 members (Maybellene, klhansen), 91 guests, and 2 robots.
Topics128,034
Posts1,055,544
Members48,425
#1605182 06/04/2026 8:18 PM
Starting to reassemble the 302 (six)
When taking the cyl head apart , the intake ports had a metal ring about 1/4” wide as well as the head to manifold/ exhaust gasket.
The engine gasket set I bought does not have these metal rings,are they important?
They are in pretty bad condition but I can make them easily enough.
O Online: Content
They're alignment rings to make sure the the parts mate properly.
1950 Chevrolet 3100 (Ol' Roy)
B Online: Content
If they are the rings shown by 8.5010 in the page from my 1955.2=60 GMC Master Parts Book, making your own is easy. Like Otto says, they are designed to align the manifold to the head. I had 2 and needed 1. My FLAPS has a selection of short exhaust pipes, some straight, some adapting some diameter pipe to another. I found one that was just a little larger diameter than what I needed, cut a short piece (make sure it is short enough that the pipe won't keep the manifold from tightening up to the head), then cut a slot across the band so you can fit it tightly into the head.
I use a socket that's a snug slip fit into the manifold passage (not the counterbore) and use it as a forming jig to make my own alignment rings. A diagonal slot isn't a problem, since the rings don't have to seal vacuum- - - - -they're just for manifold/head alignment.
Thanks, sounds simple enough
