2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 263 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 263 | I'm in the process of disassembling 235 ci, S/N 05-I6429F255XA, block casting #3836233, mfg date D225, with cylinder casting # 3835913 (mfg date D285). I've found that this engine has solid lifters and that the rocker Arm Shaft lubrication has the lub line going from the rear of engine block to the lubrication port that supplies oil to the Rocker Arm lub tube assembly. That said: should this engine have had hydraulic lifters (it has solid lifter); and two should the bolt that goes into the Rocker Arm oil gallery be drilled to allow oil flow into the Rocker Arm lubrication tube assembly (this engine's bolt does not have oil passage.)?
| | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | One of our own ‘bolters “Pre ‘68 Dave” is an expert on these Stovebolt engines and has a website that shows the differences in the rockers and oil supply thru the years these engines were made. Here is a link to his site.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | You can waste billions of electrons asking questions, and there's probably a 75/25% chance that you'll get the wrong answers. Nothing beats taking things apart and confirming what's actually there. Hydraulic lifter blocks have a BIG oil gallery drilled from front to rear through all the lifter bores, and passages from the oil pump big enough to keep them filled. Most, if not all of the late model 235 blocks had the lifter oil gallery drilled, even if they had a solid lifter (truck) camshaft from the factory. The head bolt with the 1/16" orfice drilled through it was only needed when a particular mismatch between early and late blocks and heads were used. There's no telling what has been done to a stovebolt engine since it was new, so chasing part numbers might be a fun pastime, but there's no guarantee whatsoever that a 60+ year old serial number means anything at all! Jerry
| | | | | Joined: Sep 2009 Posts: 5,999 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,999 | Texas - The serial number from your block decodes as a 1955.2 Series Regular production 235 installed in a 3600. Block and cylinder head casting numbers and dates confirm them both as 1955.2 Series 235 with the low mount large water pump casting hole in the front of the block. The regular production truck 235's were solid lifter equipped engines from the factory. You can read the full description of how the oil is circulated up to the rocker arm assembly on this page of the 1955.2 Shop Manual.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
