2 members (walter74, 1 invisible), 102 guests, and 1 robot.
Topics128,049
Posts1,055,675
Hi guys- got an overhauled 1949 GMC FC102 228 engine that needs to be run and tested. Been strongly considering a reasonably priced engine run test stand for this so I can work the rest of the truck while tinkering, fine tuning,and keep the engine safely secured until I’m ready to install at a later date. Any recommendations on an engine run test stand for this 228 stovebolt? I like the Summit SUM-918015 stand (see attached photo) with its 1500 lb capacity and ability to customize the stand as needed. I don't see how this stand will work with the front engine mount however. If I was 20 years younger I might have built my own 🙂. Thank you for recommendations.
I have several old GMC frames. They make a pretty good test stand, Here is a frame with an engine that turns that I recently bought.
I made this from a base I bought at auction for $30 and an old cherry picker. The outrigger stuff I got from McMaster Carr. I haven't put the engine run stuff on it yet. This is for a 292.
Last edited by Gdads51; 05/31/2026 1:12 PM. Reason: edit out broken pic link from text box
The thing about the Summit stand I don't like is how high up the engine is once mounted, why do you need it this high? I made my own for Pontiac V8's, it's low enough I feel safe around around it and can transport engines to the customers with out fear of it flipping off. Mine is made so the oil pan will come off, thats as high as I need it. I shopped around for cheap priced, quality gauges and already had a radiator. Cooling is the biggest concern on break-in stands, airflow around the engine does a lot keep them cool while driving, setting on a stand, the heat doesn't get blown away. I have four heavy duty fans mounted on a large shroud that mounts to the radiator, but I still have a garden hose on standby incase they start to get hot. Installing the mechanical fan works good, but is somewhat dangerous with out a shroud around it to protect you.
You will need to roll the engine outside to start and run it, be sure the wheels can handle your pavement. You also need exhaust with the quietest muffler you can find, you want to hear the engine, not the exhaust noisy.
The engine will set steady while running, there's no torque on it, the stand just needs to hold it level, the weight will hold it down. 4x4's and a set of caster wheels would work in a pinch, a water hose plumbed into the water pump with valve to control the flow rate. I broke in my 250 with water hose cooling, I just adjusted the flow according to how hot the water was coming out of the thermostat.
Mine stand has a mechanical oil pressure gauge, mechanical water temp gauge, a vacuum gauge, and tachometer. Electric fuel pump with a gauge, alternator hook up, and plugs for HEi or points ignition. Oil pressure and cooling is a must, along with a tachometer. You also need a dwell meter and timing light close by. I use a five gallon fuel container I drop a hose into. With mechanical fuel pumps, I still hook up the electric to prime the system, the mechanical pumps will pull fuel through the electric so I just shut it off once primed. The mechanical gauges work best since they read without power. My eclectic senders kept going bad, so went mechanical. I also use 2 5/8" gauges for easy reading. You want to see all the gauges from one location, you don't want to be jumping around to see them. Mine gauge panel is on a swing arm, so I can stand on the side or in front and still see them.
If I'm unsure of the ignition or carburetor, I install my own working parts so it will start right up. If they crank more than about two turns before starting, I stop and figure out why it hasn't started. Most of them start on the first few cylinders that get compression. Oil pressure is always primed before starting using a drill motor. Never use the starter to prime the oil, all the assembly lube will be wiped off before it ever starts.
I made up some battery cables, 0000 cable with well crimped ends hooked to the biggest battery I could get. I want it to crank as fast as possible and to start when I hit the button.
And on a side note, when assembling the engine, use a liquid assembly lube if you are starting the engine in a day or so, use grease type lube if it's going to set before starting. Always use a camshaft grease even if it's a used cam. This is the stuff I use on all flat tappet engines, https://www.cam-shield.com/product/camshaft-moly-paste-lube-pack/. Once I set the valve lash, I put the engine on TDC and won't turn it any more. I then use a brush and add more grease to the cam where I can get to it before finishing up the assembly. The next time it's turned will be when it starts.
I have a 400 on the stand right now,I was getting it ready to start and was priming the oil system when I notice one of the lifters wasn't pushing oil up the push rod. Had I not been pre-oiling and watching close, it would have started and likely wiped out the cam lobe in no time. This is a aftermarket roller cam conversion, the roller wasn't getting oil and the rocker wasn't getting oil. The project is on hold waiting for a replacement lifter set.
THE MOST IMPORTANT THINK I CAN TELL YOU IS, NEVER WALK AWAY FROM A RUNNING ENGINE! I loaned my first stand to guy to use, he started the engine, set the rpm, then went in the house to drink coffee for 20 minutes. When he came out the engine was stopped. He failed to get the air out of the cooling system like I showed him, the engine overheated and melted the bearings. There were balls of aluminum in the oil pan. Had he been standing there he would have seen the gauge and done something about it. It needed a total rebuild, hope the coffee was worth it!
Joe
The dyno system I had at one of the public school auto shops I ran had a water-to-water heat exchanger instead of a radiator. I'm thinking about building my own system like that, using a 55 gallon ring top oil drum and a series of copper tubing coils. The engine coolant will circulate with the engine water pump, and the drum will be filled with water. If I want to run a specific engine temperature, the drum can be equipped with a thermostat, and refilled by a toilet tank float valve. The cooling system coils will have a radiator pressure cap, just for a safety release if necessary.
You guys are always so helpful! Each of you offer such unique ideas and experience.
Crenwelge - so cool how you repurpose these old frames for run stands. Great idea!
Mick53- beautiful engine and the craftsmanship on your test stand looks outstanding as well. I noticed your 292 has side front mounts. Is there an existing engine run test stand brand name you may know of that allows for the front engine mount on the older stovebolts like mine? I wasn't seeing how that Summit stand would mount with my front mount on the lower forward end.
Joe H - thank you so much for your details. I always like a lot of detail as I always learn something new. I agree with you on the height issue on the Summit stand and I wondered the same thing. Lifting that heavy stovebolt that high could be a dangerous process I’d rather avoid. I’ll look for something shorter.
Hotrod Lincoln- love the 55 gal heat exchanger idea. You continue to be a great help on my project with your input. You gave me some intake heat plumbing ideas previously. Are you sure you’re not a closet plumber by heart? 🙂 Do you use a run stand Jerry? What are your thoughts of a brand that works well with a stovebolt?
Thank you guys!
Pat
Plumber/welder/mechanic/electrician, and a few other things I've picked up over the past 65+ years of tinkering with things! I build my own run stands from square steel tubing and angle iron, plus whatever's handy in the scrap iron stash! Somewhere WAY down the project list is an engine dyno setup on a trailer that I can drag around to various car shows and other events to draw a crowd, and maybe demonstrate a few of my Rube Goldberg modifications! I'm thinking of using a radiator from a Peterbilt, Kenworth, freightliner, etc. to cool down the water the dyno uses as a brake medium. I'll use a 4 foot diameter shop fan and a portable generator to blow lots of air over it.
I made one for a 216 out of an old frame. I cut it off just ahead of the front cab mount brackets and welded on big caster wheels under it.
I mounted the radiator support and radiator so that I could run it for extended periods at operating temperature.
I hung the stock gauge cluster where I could see it so that I could monitor temperature, oil pressure and charging system.
Thank you guys!
Pat
If you notice the front mount cradle is just bolted on. It would be easy to make one for a front center mount. There is also a sliding adjustable pad on the back for when there is no trans on the engine. I have never bought a stand so I can't help you there. Thank you for the complement.
Thanks guys. All this helps me with a plan.
