8 members (32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50, Forty9, DadsFirstPickup), 133 guests, and 2 robots.
Topics128,049
Posts1,055,658
#1604495 05/25/2026 7:51 PM
I just installed the fan blade from my 216 onto my 235 and my fan is 3/8” away from my radiator.
Is this too close? If it is, how much do these old fans flex?
Chris
ndkid275 #1604498 05/25/2026 8:31 PM
Originally Posted by ndkid275
Is this too close?
Not until you need to change your fan belt.
ndkid275 #1604503 05/25/2026 10:07 PM
Bill,
Is only 3/8” at the top due to being 1/4” higher then the fins.
ndkid275 #1604534 05/26/2026 11:10 AM
7
7 Offline
Not only do we have to be concerned about the fan blades flexing at different rpm, but also the flex of the frame/radiator core support. I think 3/8" is too close.
ndkid275 #1604542 05/26/2026 1:16 PM
O Online: Content
My stock 216 with stock fan and stock radiator is 7/8" at it's closest point.
How much flexing does the stock , 4 blade fan do at 2500rpm? What is different about the 216 fan compared to the 235 fan?
1950 Chevrolet 3100 (Ol' Roy)
ndkid275 #1604543 05/26/2026 1:25 PM
Moderator, Electrical Bay
The original fans weren't flex fans, although at higher rpms they might change shape a little bit. In your case, I wouldn't spend one second worrying because centrifugal force will be your friend. Because of it, if the blades change shape at all, they may go flatter.
Many of the original blades will be out of balance and if that's the case you can expect your water pump to not last as long. If you have any imbalance it is a problem for the shaft, bearings, seals. Are you saying your fan blade sits higher than the radiator fins? Up where the seam is? Sorry but from your words it seems like that's what you're saying but I'm not certain. Ideally you want the fan to be located in the center of the radiator fins...below the seam.
~ Jon
ndkid275 #1604552 05/26/2026 5:04 PM
I was able to figure it out. I raised the radiator 1” and I now have plenty of clearance! I’m comfortable where it’s at now.
The new blade sat 1/4” above the fins before raising the radiator. It’s centered better now.
ndkid275 #1604556 05/26/2026 6:21 PM
Good to hear. Is your front end not mounted yet?
~ Jon
ndkid275 #1604570 05/26/2026 9:44 PM
I just disconnected the radiator and slid it up.
