| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | I believe I've found a way to convert a regular 235 engine block to a 261. It involves boring the block oversize and installing a flanged sleeve intended for an aluminum block 5.3L Chevy engine. Here's the sleeve dimensions- - - -which require reboring the 235 block about the same amount as installing a 1/8" wall repair sleeve in a 235. www.jegs.com/i/Melling/689/CSL355F/10002/-1I've ordered one sleeve from JEGS, and I've got a junk 235 block to experiment on. If that doesn't work, that same sleeve can be used to repair a scored or "worn out" cylinder on a 261 to bring it back to .030" oversize. Jerry
