4 members (Wally / Montana, Otto Skorzeny, baldeagle, joe apple), 72 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#1603970 05/17/2026 5:44 PM
I have a new aftermarket turn signal switch for my 1947 Chevrolet 3100 pickup. It's the kind that mounts just beneath the steering wheel with a big clamp. In studying the instructions for installation one of the 7 wires on the new unit is to go to the brake switch and I don't see a brake switch as such. Can anyone offer any advice, please? Thanks! ray durham
bucktruck #1603972 05/17/2026 6:21 PM
Your brake light switch should be under the floorboard where the brake pedal can actuate it. What you need to do is take the output wire off of that switch (the one that runs to the brake lights) and run it to the one labeled Brake Switch on the turn signal switch. You'll also need to run an additional wire from the Turn Signal Switch to the brake lights, breaking the connection between the right and left bulbs.
I can sketch up a diagram in a bit.
[on edit]Here’s a diagram.
bucktruck #1603975 05/17/2026 7:21 PM
U
U Online: Content
I have a '46, so don't know if it's similar? Here are a couple pics before I installed my brake light switch.
~ John in Utah
Here We Go
Follow in his DITY Bay
bucktruck #1603982 05/17/2026 8:44 PM
The AD series brake light switch mounts in the same place as your '46, John.
Picture of AD Brake Light Switch
bucktruck #1603986 05/17/2026 9:35 PM
Ray: 100% of early Chevy pickups came with one light assembly at the left rear. Dealer installed option for a right side tail light.
If the right tail light is installed on yours, remove the brake wire from its source (likely the left side brake light wire) and connect it to the wire on the turn signal switch marked right rear turn signal and brake.
From the factory there will be one wire that runs from the brake light switch to the left rear tail light. Remove that wire from the brake light switch and connect it to the wire on the turn signal switch marked left rear turn signal and brake. Then run a new wire from the empty connector on the brake light switch to the wire on the turn signal switch marked brake light.
bucktruck #1604025 05/18/2026 6:57 PM
Bill,
Do you mind if I call you for more clarification? What is your cellphone number? Mine is "removed for security of member".
My email address is "removed for security of member"
ray durham
Last edited by Gdads51; 06/24/2026 1:45 PM. Reason: updated to remove personal contact info from public view
bucktruck #1604030 05/18/2026 8:47 PM
Call after 6:30pm your time.
bucktruck #1604037 05/18/2026 11:23 PM
Insomniac
Insomniac
Hey guys,
The best way to exchange contact information is through a private message. That way the whole internet can't see it.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
bucktruck #1604062 05/19/2026 1:34 PM
Ray and Bill - A big X2 to what Gord mentions in his reply. Putting personal contact info here for anybody to see may get you some really unwanted communications. Grrrr!
Be safe and share in a PM instead of the open forums.
PS - I sent you a joint PM.
~ Dan
1951 Chevy 3 window 3100
