2 members (baldeagle, Hotrod Lincoln), 84 guests, and 1 robot.
Topics128,026
Posts1,055,409
Members48,422
#1603722 05/12/2026 11:01 PM
i have a W/C T-5 trans, what pilot bushing do i need to mate it to a 270 gmc, are they all the same size od/-i/d it has nothing now. THANKS
Jay D.
jay d #1603727 05/13/2026 12:54 AM
1 Offline
Do you have the V8 transmission or four-cylinder transmission? The pilot shaft diameter for the V8 (0.668" to 0.672") or 4-cylinder (0.590")
Try this site
https://www.novak-adapt.com/catalog/pilot-bushings/gm3-pilot-bushings.html
jay d #1604023 05/18/2026 6:38 PM
I have the V-8 T-5 trans and need a pilot bushing to fit it to a 270 GMC. i believe the gmc is 1.575 or 41mm the T-5 trans is .670. i can't seem to find a part number or availability for one. am i looking at a custom made one ??
Jay D.
jay d #1604039 05/19/2026 12:17 AM
My 302 with a T5 took a 1.380"OD x .592"ID x .510" thick. Found here.
jay d #1604049 05/19/2026 3:30 AM
The stock pilot BEARING for 228, 236, 248, 256, 270 and 302 GMC six cylinder engines is a 907109. I've seen BUSHINGS used as well.
Specs are:
Inside Diameter (ID): \(0.591\) inches (\(15\) mm)
Outside Diameter (OD): \(1.378\) inches (\(35\) mm)
Width: \(0.354\) inches (\(9\) mm)
Bearing Type: Single-row angular contact ball bearing (often roller-style in historic GM applications)
Design: Typically shielded on one or both sides
These numbers are real close to MNSmith's numbers.
I got numbers of 1.575 or 40 mm for the OD of the bearing and .670 for the V8 T-5 trans a Dorman # 14673 sure hope it works as its on the way!
Jay D.
