4 members (Tronman, tclederman, Hotrod Lincoln, JW51), 149 guests, and 3 robots.
Topics128,042
Posts1,055,511
Members48,424
Page 3 of 3 1 2 3
I think the system gets overloaded when we reach 5000 or more "Guests". Paul says that John needs to implement Cloudflare (whatever the heck that is.)
5700+ again now and real slow response. Apparently these guys fly by night. I can't see IP addresses to report them. Maybe someone else can.
I was able to check a few but most I saw were US based, but a few were from England and a few were proxy servers, which can disguise the true source.
Definitely annoying.
I logged on at 10:32pm MDT and it took a couple of tries before I got in without timing out.
The "Who's Online Now" window says that there are "0 members (), 5,865 guests, and 0 robots.
0 members is surprising because I am signed in as a member.
Just figured that I would report what I saw...0 members and 5,865 guests!!
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
At 9:30 PM Alaska Daylight Time today.
They've taken over. GRRRR. I'm apparently not even here.
U
U Offline
I don't think you should eliminate "Guests", but is there a way to limit them to like 500 or so? Can it work that way?
~ John in Utah
Here We Go
Follow in his DITY Bay
8 members
57 guests ?? Where did they all go? Oh boo hoo !
Now 41 guests...... thumbs_up
Craig
On Sunday night I tried logging in several times and never did get in. It kept timing out, and I finally gave up. Tonight it's back to normal.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
U
U Offline
I've been noticing that pictures are sometimes slow to load when I'm reading someone's thread? They might load OK the first time, but when I refresh, some pictures don't load again?
~ John in Utah
Here We Go
Have had the same issue and it’s not consistent.
I have found that even though the thumbnail doesn’t show in the thread, if you click on it, it will still display in full view mode. smile
~ Dan
1951 Chevy 3 window 3100
Yeah, slow pic loading.
Craig
Red dot, center of chest ...
I don't think there's much we can do about that. Now that we have Cloudflare implemented, we've stomped out the "guests" that were plaguing us but we're experiencing the anomalies that you see when using a proxy. It may get better with time, as more content gets served directly from Cloudflare, but who knows?
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
I'm getting intermittent time-outs today. Usually gets back in when I refresh. ohwell
Page 3 of 3 1 2 3
Moderated by  baldeagle, Gord&Fran
