I think the system gets overloaded when we reach 5000 or more "Guests". Paul says that John needs to implement Cloudflare (whatever the heck that is.)
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
5700+ again now and real slow response. Apparently these guys fly by night. I can't see IP addresses to report them. Maybe someone else can.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
I was able to check a few but most I saw were US based, but a few were from England and a few were proxy servers, which can disguise the true source.
Definitely annoying.
I logged on at 10:32pm MDT and it took a couple of tries before I got in without timing out. The "Who's Online Now" window says that there are "0 members (), 5,865 guests, and 0 robots. 0 members is surprising because I am signed in as a member.
Just figured that I would report what I saw...0 members and 5,865 guests!!
Nick 1940 KC Model 1/2 Ton Pickup Project (with '37-'39 Bed and what we think is a '42-'46 Frame) Taos, New Mexico
They've taken over. GRRRR. I'm apparently not even here.
My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
I've been noticing that pictures are sometimes slow to load when I'm reading someone's thread? They might load OK the first time, but when I refresh, some pictures don't load again?
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engine Here We Go Follow in his DITY Bay
I have found that even though the thumbnail doesn’t show in the thread, if you click on it, it will still display in full view mode.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
I don't think there's much we can do about that. Now that we have Cloudflare implemented, we've stomped out the "guests" that were plaguing us but we're experiencing the anomalies that you see when using a proxy. It may get better with time, as more content gets served directly from Cloudflare, but who knows?
I'm getting intermittent time-outs today. Usually gets back in when I refresh.
