0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1603661 05/12/2026 2:06 AM
Have a 1954 235ci Chevy engine. Having trouble threading in the temp. sensor into the head. Does anyone know the thread size used there, is it possibly a pipe thread size. Last year at this time I had the sensor out, but it seam to screw in fine then but won't now. Thought I would try and run a tap in the hole, but unsure of the size. Any help appreciated!
Thanks, Tom
Should be a straight thread with a tapered seat on the bottom. That's assuming it's the same as a 216ci, which it should be. I could go measure it for you on my engine sitting in the garage.
[on edit] can't get a good measurement on the port in the head, but tomorrow, I'll measure the sensor thread. It's definitely a straight thread.
Thanks Kevin, I think I may have found the thread size, 5/8 x 18, and yes a straight thread. That size was last used in the 1955 235 motor. If you have a chance, please verify the size (and my information).
Tom
Confirmed at 5/8 inch, 18 TPI.
