1 members (Woodcmiami),
72
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | I just put my rebuilt 216 (modified with a 235 crank) engine back in the truck and am having issues getting it to fire up. Have checked timing multiple times and the best we have gotten is a kickback when one cylinder fires prematurely and the latest thing is a single loud pop out the exhaust (no exhaust pipe yet.) I'm suspicious of the starter drawing the voltage down too low to fire the ignition. Had some issues with the coil wire too close to the distributor cap clip. Still the original 6 volt system and the battery is fully charged at 6.2V. Thinking of isolating the battery from the starter and cranking with a 12V battery so the ignition gets a full 6V. Any input from the Stovebolt Collective?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | So RTFI applies here.  I was setting the initial timing with the pointer on the BB on the flywheel instead of the U/C mark. Will go back and check timing again this afternoon.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,698 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,698 | Race Tuned Fuel Injection?
Radiographic Testing Film Interpretation?
What does RTFI mean?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jul 2018 Posts: 266 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 266 |
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Jan 2022 Posts: 2,436 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,436 | My Dad's version of RTFI was "When all else fails look in the trash for the instructions".
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | "We don't need no stinking instructions"  Oh, WAIT!!!
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,698 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,698 | Ok.
My dad always said "Read the manual!"
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | 6.2 volts seems pretty low to me. Are you sure that you had the number one piston at the top the cylinder on the compression stroke when you dropped in the distributor? Needle on the ball is where you need to be in order to start and run. The other marks on the flywheel are for checking static valve train specs. I'm thinking that you already know all of this. I am just kindly suggesting that you double check some things.
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | Thanks Carl, Fully charged 6V is 6.3-6.4V, so I'm a little low, but had been cranking a bit. The book says set static timing on the U/C mark on the flywheel when installing the distributor (page 12-29) with #1 at TDC compression, and use the ball with a timing light when running (page 6-19.) Why it wasn't in the same place in the manual? Would have been easier to find.
I'll be double checking things when I retry. Will also measure cranking voltage at the coil to rule out a dragging starter.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | "Needle on the ball- - - - -both #1 valves closed"! The ball comes up twice- - - -once at the top of the compression stroke of #1 cylinder, and again one turn later with #6 on compression. Watch the #6 valves as you rotate the engine- - - -when the exhaust valve closes fully and the intake starts to open- - - - -install the distributor with the rotor pointing toward the #1 spark plug wire on the distributor cap! Jerry
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | That's not what the service manual says. It says to use the U/C mark for static timing while installing the distributor.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,436 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,436 | The few degrees of difference between the BB and UIC won't keep the engine from starting. Something else is wrong. Check distributor for 153624 rotating clockwise. Also check for #1 firing when both valves closed like Jerry says. Could be you are 180 degrees out on the distributor like Jerry implies.
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Yup, sounds like it's off 180 degrees
| | | | | Joined: Feb 2005 Posts: 1,632 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,632 | When I did my start up last year, I set the pointer on the BB. With spark plugs removed, I blew air into #1 to make sure it was sealed up. Then I was sure I had it at TDC. #6 air just blew through. On my recent struggle with my start up, my condenser ended up being bad.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | That's not what the service manual says. It says to use the U/C mark for static timing while installing the distributor. I guess I've been doing it wrong for 65+ years, then. Never failed to start. U/C is used for valve adjusting. Jerry
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | Yup, sounds like it's off 180 degrees It was 180 off. Fixed that and made one start attempt, but needed to recharge the battery. Firing order was confirmed correct. I may install Jon G's condenser and see whether that makes a difference. It was running previously with the same condenser, but that doesn't mean it hasn't gone bad.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Can you use #6 plug wire to time it? Is my thinking bonkers? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2022 Posts: 2,436 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,436 | Can you use #6 plug wire to time it? Yes. #6 piston is exactly the same place on the crankshaft degree wise as is #1. #6 spark plug should fire every other turn of the crankshaft alternating with #1. You shouldn't be able to tell the difference with a timing light.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | He who has never dropped a distributor in 180 degrees out hasn't been doing it long enough.
| | | | | Joined: Feb 2005 Posts: 1,632 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,632 | ... It was running previously with the same condenser, but that doesn't mean it hasn't gone bad. My wiring expertise (or lack there of) probably caused me to burn out my condenser. Sure glad I had spare.
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | Well, it's running. I did put Jon G's condenser in, but no joy. It would try, but refuse to continue running. So I triple-checked the firing order and discovered that dyslexia had gotten me. Plug wires for #2 and #4 were switched. Once that was fixed, it fired up and ran nicely. Thanks everyone for the suggestions. Sometimes it takes a village (of stovebolters.)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Kevin, Congratulations! Come to find out, at a late stage of life, I'm dyslexic. I feel your pain, once that little fact was explained a very few years ago, all I could say was....Yelp. On firing orders, anytime a friend asks for help getting a rig running right after they've worked on it, first thing I do is pull all the plug wires from the distributor cap, pull number 1 plug, find TDC, and following the firing order wire the cap. There's always lots of conversation on how they've already done that. Occasionally it really is the firing order that was mysteriously out of wack. Would love to see your rig and see the modded 216 in action.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I plead guilty dropping in the distributor 180-out and using #6 for timing.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | He who has never crossed spark plug wires right after dropping a distributor in 180 degrees out hasn't been doing it long enough as well. smile
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | It is amazing how few cylinders a Stovebolt will run on. I also “know a guy” who has managed to cross up plug wires.
1951 3100
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | It is amazing how few cylinders a Stovebolt will run on. I also “know a guy” who has managed to cross up plug wires. It was amazing the difference in non-starting with the crosses wires and after correcting. It fired up and ran immediately, but couldn't quite make it when the wires were crossed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,436 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,436 | I usually just forget that I put the rotor in my pocket while I'm changing points and then wonder why the engine won't start.
| | | | | Joined: Feb 2005 Posts: 1,632 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,632 | ... I usually just forget that I put the rotor in my pocket while I'm changing points and then wonder why the engine won't start. Yep. I put mine on the cover by the radiator. When I walked around the front to see why it wasn't starting, I noticed the rotor on the ground. I was glad in didn't crack.
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | Bolters, please keep this thread on topic and stovebolt related!
After this thread left the Stovebolt world, I removed several posts that were not stovebolt related and removed text from others that referred to non Stovebolt engines.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
