7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible),
99
Mod | | | Forums66 Topics128,136 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 47 | What would be the best replacement tires (size and brand) for my 1949 stock 3100?
1949 3100
| | | | | Joined: Oct 2021 Posts: 6,834 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,834 | Do you have 16" rims? 215-85R16 are the closest in size (outside diameter and width) to the original bias ply tires (700-16). They're normally found as light truck tires (LT 215/85R16) Brand is up to you. Find a tread and sidewall design you like. They can be found for about $100 each up to $300+ for aggressive off road treads. If you want a bias ply appearance, look at Diamondback Tires. High quality radials with vintage look and excellent quality and handling. Not cheap. www.dbtires.com
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | That the size my truck uses. Mucho Perfecto!
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2017 Posts: 664 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 664 | Evoluxx Rotator H/T 195/75R16 Load D 8 Ply Van Commercial I put these on my 1950 3100 16" . I love them. Smooth ride. No complaints so far. 1,000+ miles now. I found them on E-Pay...
1950 Chevy 3100
| | | | | Joined: Nov 2005 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 56 | If you switch to radials you may have to use a radial tube. be sure to check. I shopped tires and wheels by my 3800 DRW.... | | |
