5 members (NJC, Gdads51, ronsway, Hush, 1 invisible), 143 guests, and 0 robots.
Topics128,101
Posts1,056,179
Members48,436
#1603624 05/11/2026 2:03 PM
Today’s project, installing valve seats on a 302.
What the distance of the the valve stem protruding from the top side of the head, when installed properly?
In other words words, how deep should the valve seat be installed?
Dave
The 248 head I have in the shop measures 2" from the top of the valve stem to the milled surface where the rocker shaft stands bolt on. The bottom of the valve springs look like they're recessed about 1/8" below that level. Are the valve seats worn out too badly to regrind?
The exhaust valves will be OK, but the intakes where rusted badly,something to do with sitting in the weather for forty years?!
Use regular cast iron seat rings. RUN- - - -do not walk away from stellite hard seats! If you can find stainless steel exhaust valves with the correct length, stem, and head diameter, use them instead of buying into the myth that the exhaust needs hard seats.
I have cast iron seats
I'm curious why you'd want to use the old cast iron rings in a modern day rebuild. Moly rings are better in every way, and it's not like they're hugely expensive. Is there a downside that I don't know about?
Tronman - They're talking about valve seats in the head, not piston rings. wink
~ Dan
1951 Chevy 3 window 3100
Oh, <duh> sorry about that. I didn't know you could get cast iron valve seats.. why would you, when you could get stellite once, and never have to worry about it again? 25 years into a set of 'em in the Cadi V8 in my bus. The valves were sinking into the stock iron heads under the load of this heavy rig. That stopped when Valley Head Service in LA, redid my heads and installed hardened seats. 22 years later when I took it apart to freshen it up.. the exhaust valves were barely touched and the machine shop said it was a breeze to spiff 'em back up. Only one hole was even leaking down when I compression tested it before disassembly.
To each their own, but I don't understand why there's anything wrong with hardened exhaust seats. Cadillac did induction harden the exhaust seats at the factory, however once you get a valve grind or two in, that hardening is compromised. Hence the renewal.
