5 members (50Chevy3100, tclederman, Gazz, Gdads51, Truckin39), 86 guests, and 2 robots.
Topics128,093
Posts1,056,463
Members48,443
#1603421 05/08/2026 1:19 AM
There is a large plug on my 235 intake under the carb. Would this work for wiper vacuum, or do I need a fuel pump with the vacuum pod?
Short answer is typically yes for wipers to pull vacuum from the intake manifold, that is also the port used for a pcv if you go that route (which might be a good idea).
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
You're using it for both?
Yes both, if the pcv valve is sized correctly it only draws modest pulses. As traditional with vacuum wipers they do not work at full throttle like when climbing a hill, with or without the pcv.
Chuck
2023 Miata RF Club
Did the fuel pump with vacuum fix that problem? I would assume so since no loss of vacuum.
U
U Offline
Mine was coming from the intake manifold, but I haven't hooked up anything new yet. Trying to decide if I want vacuum or electric.
~ John in Utah
Here We Go
Follow in his DITY Bay
I installed a vacuum reservoir under the dash (made it from an empty propane canister - see the attached pic) in the hope that the reservoir would have enough vacuum to carry the wiper thru the full throttle events. I haven't tried it out yet. My fallback position is to install a fuel/vacuum pump. I just finished rebuilding one of those.
Looks great Kevin. I've had a 5 gallon vacuum tank off an old 43' flatbed trailer in the shop for a few years. Plan was to mount it under the truck on the frame for the wipers. However I got to thinking about how long it'd take to replenish the vacuum if I ever used all the stored vacuum on a big hill. And the tank still waits on me to do something, maybe buy an electric pump to supplement the trucks vacuum? Or copy your tank, I'm thinking that's a better option.
RonR
RonR
1970 340 Duster
1964 CJ5
