| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16034 02/03/2005 8:06 PM | Joined: Jan 2005 Posts: 2 Junior Member | | Junior Member Joined: Jan 2005 Posts: 2 | I am having a huge problem figuring out why my '49 216 idles perfect and runs strong in the upper rpm range but when I go to shift under load (up hills) it falls on it's face and sputters and I have to baby the throttle to get into the power range. :mad: I"ve checked the timing and the advance which appears to be fine. Any Ideas??? Thanks ND | | |
#16035 02/03/2005 8:34 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | What about the carby? Fuel filter?
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#16036 02/03/2005 9:11 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have a rochester B model carb take the top off & make shure the power booster rod mooves up & down freely & goes into the center of the ball. Check the float level.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
