1 members (Dusty53), 174 guests, and 4 robots.
Topics128,101
Posts1,056,180
Members48,436
#1603057 05/03/2026 6:16 PM
Twenty years ago when I built my first truck I seem to recall that there was a way of morphing a regular AD fender into one that would accommodate a spare tire. A section could be cut out, turned over, and welded in place. This was done using a specific pattern in a precise location. I don't like carrying a spare under the bed, so would like to try this. Where can I find the pattern and instructions?
U
U Offline
I remember seeing a YouTube series on doing just that. LINK I didn't watch all the videos - not sure this will help?
~ John in Utah
Here We Go
Follow in his DITY Bay
Good link. I watched all the videos, but he cut out the concavity from an old fender and welded it into a new one. If I had the old fender, I would just repair it and use it. I may be mis-remembering the concept of cutting the convex brow of a new fender, inverting it, and re-installing it as a concavity.
U
U Offline
How about this one in our Tech Tips section. LINK
~ John in Utah
Here We Go
That is exactly what I am looking for. Thank you.
It might be a good idea to make the template out of some type of heavy cloth like denim instead of paper- - - -it would probably conform to the shape of the fender better, especially if you wet it down first.
Attention moderator---the tip by Ray Stanley (2005) is just what I need, but several photos referenced in the text do not appear, and the photo of the template on the fender isn't clear enough to make out the dimensions
U
U Offline
I can see these - hope this helps.
~ John in Utah
Here We Go
Here a screenshot of the last overall picture to complete the set posted by John above. wink
~ Dan
1951 Chevy 3 window 3100
Thank you, gentlemen. Just what I needed
